Old 10-27-2015, 05:46 AM
EBmotorsports's Avatar
EBmotorsports EBmotorsports is offline
Default Need help, lengthen torque tube?
Hey guys,
I'm starting a new project and we are discussing suspension options. We are looking at buying a c5 corvette complete chassis setup but the wheelbase is about 6" too short. I've done some searching and it looks like the torque tube can be lengthened but I've not found any details to it. Has anyone here done that or had it done? If so could you please provide me with some details. Is it a simple cut and weld deal? Any help would be appreciated before we spend the money on the chassis. Thanks in advance
EB Motorsports
Eugene Braswell, Owner
http:///www.ebmotorsports.com/
Old 10-27-2015, 12:31 PM
Build-It-Break-it's Avatar
From what I've read its just simply cutting two torque tubes and making one. Measure ,cut, weld.
Ahmad B
Old 10-27-2015, 02:46 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
We have done it and can do it again.
We use new aluminum tubing.. Cut the ends off & machine the bell housing to accept the OD of the tube.. then weld it up!
You could probably cut the middle & add a section too, just have to make sure everything is perfectly square.
Driveshafts we usually source from Driveshaft Shop.
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 10-27-2015, 08:10 PM
Ok great, thanks for the input. I hadn't thought about taking a second one to add to the length. I just figured I would put a section of tube in.
Do you guys use the carbon fiber driveshafts for these?
EB Motorsports
Old 11-17-2015, 11:48 AM
nickcornilsen's Avatar
nickcornilsen nickcornilsen is offline
The length of extension will determine if you need a CF driveshaft or not. I extended one 8" and did not need to, but did need to go with a slightly larger tubing diameter.
-Nick
