Old 07-08-2006, 08:45 AM
KillaCamaro67 KillaCamaro67 is offline
Default DSE mini tubbing finished.. need a shortened rear axle, what to do?
Well ive been asking around about what folks did when they shorteded their axle so i figured id ask the good guys at LateralG..
what did you guys do?
modify the stock one?
ive been looking at a Moser one but i dunno which one is complete and shortened the right depth.. so i can just put it in
any advice?
thanks guys!!
heres some tatates to help jog memories..
Old 07-08-2006, 10:11 AM
We can set you up with correct offsets / tires, and rear dimensions and the parts.
Frank Serafine
Old 07-08-2006, 09:55 PM
JamesD's Avatar
JamesD JamesD is offline
Do most people narrow their rear ends? Is it becauase wheels looks strange when they are really wide with positive offsets?
Old 07-08-2006, 10:48 PM
mazspeed's Avatar
mazspeed mazspeed is offline
What was the question again?
Old 07-09-2006, 07:10 AM
mdprovee's Avatar
mdprovee mdprovee is offline
I had my 12 bolt rear end shortened, and new ends put on. I believe it was shortened 2" on each side. Wheels are 17 X 11 with 5 1/2" offset.
Mike
Old 07-09-2006, 08:13 AM
when you say put new ends on what do you mean?
and how much does something like that run?
Old 07-10-2006, 08:16 AM
mdprovee's Avatar
I had mine done at Meanstreets Performance, Vince did it. He would have all the answers. He created a page of what he did.
http://hometown.aol.com/gumbydmit22/mpcamaro.html
His email is [email protected]
Mike
Old 07-10-2006, 12:25 PM
Payton King's Avatar
Default go to Prodigy or
If you are into doing it yourself you need to select your tire rim combo first, brakes and then measure for the width of the rear.
Old 07-31-2006, 06:09 PM
67PTCAMARO 67PTCAMARO is offline
Can't one get the wheel to fit rear end? is there a optimal point where the center of the wheel should be?
67LS1T56
Old 08-04-2006, 05:58 PM
Vince@Meanstreets's Avatar
Can you elaborate please?
