Old 11-09-2015, 02:36 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Default T56 Magnum Wiring Pigtail Kit by Schwartz Performance
Let me guess.. You bought a new T56 Magnum and realized you need some wiring pigtails to complete the install!
We've got a nice little kit available for T56 Magnums that includes everything you need. Speedo/VSS pigtail, Reverse light pigtail, reverse lockout pigtail, and most importantly, a plug for your mechanical speedo hole. (The rubber plug that is in there from the factory won't last you terribly long!).
This works on both Ford & GM T56 Magnums, doesn't matter the ratio. This kit is only if you have an electric speedo. Will not work on LS1 T56's as there is no mechanical speedo for that, and a different VSS plug.
Contact us for other configurations.
PURCHASE HERE: http://www.schwartzperformance.com/p...g-pigtail-kit/
USE SPECIAL DISCOUNT CODE "T56WIRING" FOR $10 SAVINGS!
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
