Old 11-20-2015, 10:37 AM
69hugger's Avatar
69hugger 69hugger is offline
Default Power booster issue
I have a 9" dual diaphragm booster & stock GM master cylinder powering my Baer 6S 14" front & Baer 12" rears. The brakes have been working perfectly until the last week or so.
It has started losing power assist randomly.
The engine has good vacuum. I have checked the check valve that snaps into the booster & it works fine. I'm fairly certain there are no vacuum leaks, and wouldn't think a vacuum leak would result in a random failure.
My question is whether a failed/ failing booster can do so randomly? Could 1 of the 2 diaphragms be bad?
I am happy to replace the booster, but hate to do so & find I have the same issue. It is the end of the season up here & it will be 5 or 6 months before I will know.
Anyone ever experienced something like this?
Thanks for any thoughts.
Bill
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 12-03-2015, 12:52 AM
Vince@Meanstreets's Avatar
Bill
Hi Bill,
Did you ever get this figured out?
One customer was experiencing the same symptoms and turned out he was using a regular hose for the vac feed. Every so often it would suck closed.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-22-2015, 06:23 AM
69hugger's Avatar
Vince,
Sorry, I missed your question. I didn't. As I wanted to upgrade the stock master cylinder anyway, and was pulling the car apart for the winter, I just decided to ditch the booster altogether & just put a Hyraboost setup in it.
FWIW, I DID talk to a few power booster experts that said they had not heard of my intermittent problem. (I'm sure mine can't be the only time in history this has happened....)
I did inspect the supply hose & it was fine. Fuel rated, thick wall hose, no holes in it, even put a vacuum pump on it & it was fine. I'm sure there's an issue buried in the booster, but I don't see how it comes apart, and I guess I don't care enough to try to take it apart to find out.
I dunno, it's a mystery to me....
Bill
Bill
