Old 12-07-2015, 08:54 AM
Colby@HDC's Avatar
Colby@HDC Colby@HDC is offline
Default Hurst Driveline Conversions 1967-1973 Ford Mustang kit
The Hurst Driveline Conversions 1967-1973 Mustang ELITE Tremec TKO kits include the following components:
Transmission: All new Tremec TKO-500 or TKO-600 transmission
Crossmember: Custom crossmember. Direct bolt in – no modifications required.
Driveshaft: 3 1/2″ steel driveshaft complete with premium Heavy Duty u-joints and Heavy Duty slip yoke, custom built for your car. All driveshafts are balanced using state-of-the-art equipment. Aluminum driveshafts also available for an additional charge.
Speedometer cable/adapter: Custom mechanical speedometer cable with integrated adapter and gear. Electric speedometer kits are also available.
Pilot bearing: Custom made needle roller pilot bearing.
Transmission mount: Energy Suspension polyurethane transmission mount for long life and durability.
Bellhousing: Custom aluminum bellhousing designed for the Tremec TKO-to-Ford engine block 289,302,351W/C application. Big block scattershields also available.
Starter Index: Starter index plate for the bellhousing.
Clutch kit: High Performance 550 HP clutch kit complete with disc, diaphragm pressure plate, custom throw out bearing, clutch alignment tool and hardware.
Clutch Fork: Ford mechanical clutch fork.
Flywheel: Billet steel flywheel. Includes grade 8 flywheel bolt set.
Shift stick: Hurst Chrome shifter handle.
Shifter ball: Your choice of a Hurst white or black 5 speed pattern shifter ball.
Reverse light switch connector: Convenient pigtail connector.
Tunnel patches: Pre-formed tunnel patches. Includes cutting template.
Drive shaft shield: Drive shaft protection shield
Hardware kit: Complete specialty hardware kit for a hassle free installation.
Installation instructions/information: Step-by-step, illustrated car model specific instruction manual to answer your most detailed questions and help you with your installation.
Customer support: Unlimited, lifetime technical support. Rated #1 in customer support and service.
Extended warranty: Free one year extended warranty from Hurst Driveline Conversions on all kit components. Some restrictions apply
If you would like additional information on this or any of our other parts or kits, give us a call at 707-535-3030 or visit our website, www.hurst-drivelines.com
Old 06-22-2016, 03:54 PM
Hurst_Drivelines's Avatar
Hurst_Drivelines Hurst_Drivelines is offline
We figured that it might be a good idea to update this thread considering that we have since revised and extended our warranty coverage.
HDC now offers an industry leading 30-month warranty on individual components, including transmissions, and kit parts.
