Old 12-07-2015, 11:36 AM
paulk68 paulk68 is offline
Default Camaro Idler arm and pitman arm castle nut
does anyone know the torque specs for the castle nut that connects the idler arm and pitman arm to the centerlink on a 68 camaro?
thanks
Old 12-07-2015, 12:16 PM
ilikeike's Avatar
ilikeike ilikeike is offline
I was looking in the factory assembly manual, the only spec I see for castle nuts are the tie rod ends, aren't they the same size/thread as the centerlink?
Strange there's no callout on the centerlink nuts,that's why i'm thinking since it's the same castle nut, the tq. is the same as the tie rods.
30~40 lbs-ft (50 lbs-ft max to line up the hole for cotter pin)
