Old 12-12-2015, 08:50 AM
RdHuggr68 RdHuggr68 is offline
Default Drill Press
I just bought a drill press from Lowes, (Porter Cable) and I bought a drill press vise for it. I am not sure how it mounts to the table, It has the long slotted grooves in the table but they are big grooves. I pictured a bolt head fitting in there tight but the groove is huge. Any help would be appreciated because I have not found any info online.
Kevin
Old 12-12-2015, 09:03 AM
Kevin
I am going to try putting washers on the bolts, I quess I did'nt think this out before I started this thread.
Old 12-12-2015, 09:35 AM
Those are called T slots --- there's pretty inexpensive kits for them.... You need to get the owners manual out and see what size the slots are - my guess is 1/2" or 5/8" (pretty standard sizes).
Then pick up something like this: As shown it's a 1/2" kit.
http://www.grizzly.com/products/58-p...-T-Slots/G1075
Old 12-12-2015, 09:41 AM
Here -- watch this if this is the kind of "table" you're referring to.
Old 12-13-2015, 06:52 AM
Thanks Greg, the Grizzly kit looks like the way to go, The owners manual doesn't show anything as far as size goes, I think I should be able to figure out the correct size. Thanks again for all the info, I have to go out and shovel all this white s### off of my driveway now. I need your snow blower.
Kevin
Old 12-13-2015, 08:58 AM
The slots are 5/8"
Not sure if they're T slots or not - can't tell from the crappy photos on the website...
Old 12-15-2015, 01:22 PM
The slots are 5/8"
Greg, the slots on my drill press table are a little over an inch. It is a Porter Cable, got it at Lowes. I will check out that website and see if they have anything that size. Thanks for your help.
Kevin
Old 12-15-2015, 02:12 PM
Kevin
I measured at base of table, I should have measured at the surface. Its 5/8" and I placed my order with Gizzly Industries.
