Old 12-15-2015, 08:27 PM
SSLance's Avatar
SSLance SSLance is offline
Default Help me pick the right cam
So, I'm stepping up the HP from my crate engine this winter and step 1 has been put into motion. Today I picked up the new to me heads, so now it's time to pick a cam to go with them.
Here are my short block specs:
4.00 bore x 3.80 stroke (383 cu), dished pistons about .0030 into the deck, Comp ratio was 9.1:1 with 64 cc iron vortec heads
I picked up a set of GM Fastburn heads that have been upgraded at Brzezinski with Beehive springs and chrome moly retainers. http://www.castheads.com/cylinder-he...4-crate-motor/
These heads have a 62cc combustion camber, 210 cc Intake runner, 2.000 Int/1.550 Exh valves and when used along with a thinner MLS head gasket will increase the compression ratio to 9.6:1.
I have on hand this cam which came in the 604 Crate engine.
Camshaft Part #10185071
Valve Lift: .474” Intake, .510”
Exhaust Duration: 208° lntake, 221° Exhaust @ .050”
Centerline: 112° ATDC Intake, 112° BTDC Exhaust
This is the cam that comes in GM's SP383 which I'm modeling my build after. http://www.chevrolet.com/performance...nes/sp383.html
Camshaft Type (P/N 19210723): Hydraulic roller
Valve Lift (in): .509 intake / .528 exhaust
Camshaft Duration (@.050 in): 222° intake / 230° exhaust
The one difference between my build and the SP383 above is I'd like to use my Dual plane intake manifold instead of the single plane high rise manifold that comes on the SP383 and 604 crate. I have one of those intakes as well, so it's possible to use...but I'd like to keep my Qjet and I think the dual plane will fit my needs of low end torque better than the Victor Jr style.
So, any thoughts on cam choice? Most of you know I'm not looking for a high RPM screamer nor drag race engine. I need a rock solid steady performer that will pull between 3000 RPM to 6000 RPM repeatedly and steadily. Performance and reliability are more important to me that a full on peak HP number.
These heads and whichever cam I choose are a huge upgrade from the truck engine cam in my engine now, conservatively a 100 HP/50 ft lbs increase in all the right spots. I'd just like to make only one cam choice and am looking for some help in this matter.
Oh yeah, here's what Santa brought me today...since I know you all like pics...
Lance
