Old 12-16-2015, 02:35 PM
1965_SS's Avatar
1965_SS 1965_SS is offline
Default LS3 Oil Pan Gasket
I've got a new GM crate LS3. I need to change the stock oil pan over to a Holley for my car. Is it ok to reuse the pan gasket or do I need to buy a new one?
Thanks.
_________
1965 Chevelle SS
Project Build
Old 12-16-2015, 05:26 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Reuse the one that came on the crate motor. You'll need to drill out the 2 rivets.
Old 12-16-2015, 08:59 PM
randy randy is offline
Exactly what he said. Drill the rivets out and when reinstalling i actually used a thin coat of silicone.
Old 12-17-2015, 06:34 AM
Vega$69's Avatar
Only put sealant on the 4 corners where the front and rear covers meet the block
Old 12-17-2015, 08:43 AM
1965_SS's Avatar
Wow, thanks for the replies! I would have never known to do that. Once I get the pan off I'm sure I will see the rivets you guys are talking about (still sitting on crate).
Any good LS books out there to get my knowledge up on these engines?
_________
1965 Chevelle SS
Project Build
Old 12-17-2015, 03:37 PM
You drill the holes before you take the pan off. Undo all the bolts. Tap the pan with a mallet, and lift. You will see where the rivets are holding it on. Make sure you have a razor blade also as you might need it
