Anyone that buys a USED motor - should expect the expense of having to rebuild it. As long as you factor that in... then it doesn't matter what motor you buy. It's a gamble. If you assume the risk and are prepared for it ($$$) great. If you think you're just going to buy a "cheap" motor and use it as is..... good luck! You might need it.
