Old 12-21-2015, 05:06 PM
lsuguy's Avatar
lsuguy lsuguy is offline
Default VA Hose Routing
I am working on installing my VA unit and have everything mocked up. Will it cause any issues using the existing fresh air hole to go into the cowl and then doing a bulkhead close to where the original hole in the firewall is?
I have a smoothed firewall and using a ii much fab bulkhead along with ez clip hoses so bend radius isn't as much of a problem.
I just need to make sure running the hoses through there isn't going to cause any issues....
