Old 12-23-2015, 10:37 PM
wookham's Avatar
wookham wookham is offline
Default quick easy question..1968 firebird
I don't remember the tire size I need for the front....1968 firebird im going to run a set of the 17 inch billet ralleys on the car...will this combo fit.....fronts will be a 17x8 245/40-17 4.5 bs....rear 17x9 275/40-17 5.0 bs...the car is stock ride height..may drop it two inches
thanks in advance
Old 12-26-2015, 08:59 AM
JMitch19's Avatar
JMitch19 JMitch19 is offline
thanks in advance
Most people run 4 7/8 - 5" BS is the front. I had 17x8 with 4 7/8" BS with a 245/45/17 on my 68 Camaro. I had to run a 5/16" spacer to clear my brakes. This made my effective BS 4 9/16". At 4 9/16" I would get rubbing at 12 o'clock on the inner fender when I hit bumps. This would have been worse with 4 1/2" BS. I ended up swapping wheels to a 18x8.5 with 5 1/4" BS with a 245/40/18. I didn't have any rubbing issues with this combo.
When I had the stock width rear in my 68 I was running a 18x9 with 5 1/2" BS with a 275/35/18. I wouldn't have been able to run 5" BS. If anything I'd have been better off with 5 7/8".
Every car is different so your best bet is to measure for yourself, but that is what worked on my car. I assuming the 68 Camaro's and Firdbird's are similar in fitment.
Jason Mitchell
1971 Camaro 416 LT1 Project
