Old 12-26-2015, 10:59 AM
jblaine86 jblaine86 is offline
Default Tig welder help
I am new to tig welding and wanted to tig weld my pypes 304 stainless steel exhaust. My question is, what tig wire material would be the best for this?
Thanks,
Jon
Old 12-26-2015, 11:49 AM
Vince@Meanstreets's Avatar
you can use 308 or 316....I use 316 for filler but if I prep right fuse no filler.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-26-2015, 12:27 PM
Thanks,
Jon
TIG or MIG??? MIG uses wire --- as in a roll of it.... TIG uses fill material
Old 12-26-2015, 12:48 PM
Thanks for responses. Yes I was looking for fill material
Old 12-26-2015, 12:53 PM
filler rod
Dealer for
NEVER FORGET -11
Old 12-29-2015, 09:33 AM
LS1-IROC's Avatar
LS1-IROC LS1-IROC is offline
I would recommend back purging your welds on stainless. I find that using small diameter filler is easier. I have started using .030" mig wire recently and that works great with a 1/16" tungsten.
Old 12-30-2015, 07:27 PM
Thanks. I just got some scrap pieces today to practice with this weekend
Old 12-30-2015, 07:59 PM
Agreed.....btw the cleaner the better for TIG work on stainless steel
Old 01-05-2016, 12:51 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
While we are on the subject of TIG, I have been looking for a TIG welder and frankly I have only suceeded in confusing myself. What TIG welders do you guys recommend?
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 01-05-2016, 01:52 PM
Like most things these questions are budget dependent.... there are great machines that can do everything and there are budget machines that can "TIG" weld....
I run a Miller Dynasty 200 DX and it does everything.... and has been trouble free. IT can do more than I can do or need to do. But when you buy this stuff - you want to buy the best one you can because they hold their value and you don't know what welding you're going to want to do going forward.
