Old 01-04-2016, 05:16 AM
Craig-Aus's Avatar
Craig-Aus Craig-Aus is offline
Default 1970 VF Valiant (An Australian Dodge Dart) By BMV Engineering
Hi guys and girls. My name is Craig I am from BMV Engineering a small shop in Queensland Australia. This is a build the has been going for a little while now but have only now decided to put up a build of the car. The car is a VF Valiant coupe witch is pretty similar to your 1970 Dodge Dart. The main difference being the front sheet metal. Australia is pretty strict on modifying cars with all major mods needing an engineers approval eg: Chassis and suspension work and all smaller mods like engines and drive train needing a modification plate. Basically paying people money to allow you to make your old car safer. But at least that way there is not as much bad workman ship.
So this is a VF Crysler Valiant. Not the one we started with but just an example.
The Valiant was a uni body car but we are running a full chassis but then tying it into the body again so it remains a uni bodied car. The main frame rails are 4"x2" and the rear notch section starts at 4" but reduces to 3" at the end of the notch.
Basic chassis in place
Had some issues on the rear quarters that needed to be fixed.
The front end was designed to be like a bolt on kit you might use on a Nova or Camaro except welded in place
The un official saying at work is we dont build show cars. Our customers drive their cars. So with the rear end we have 3" of adjustment for the 4 link. We can move the ride height higher and lower and still keep the 4 link at its correct geometry as we made multiple mounting points. The same for the coil overs.
Rear boot section mocked in place.
Old 01-04-2016, 05:17 AM
Craig-Aus's Avatar
Took her off the jig and pushed her outside for a visual and no the wheels are not staying.
Onto the inside. The floor is going to be double skinned there is support under the top floor section to keep it flat and the sills will wrap under to the chassis rails.
Thanks Craig
BMV Engineering
Australia
Old 01-04-2016, 05:27 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Amazing fab work,I really like it
Old 01-04-2016, 09:11 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
^^^^Yeah, what he said.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 01-04-2016, 09:29 AM
carbuff's Avatar
carbuff carbuff is offline
You put the steering rack in backwards!
Looks nice. Thanx for posting...
Old 01-04-2016, 01:39 PM
trevor572 trevor572 is offline
Thumbs up Hi.
Hi. Love your work guy's. Where in Queensland are you located. You must have a DOT guy with a labrador and a white cane. lol. Cheers Trevor.
Old 01-04-2016, 04:37 PM
NOVA NOVA is offline
Thumbs up
clean Fab work ...
Forgelines - Ridetech - DSE Tubs - ZZ4/700R
Old 01-04-2016, 11:50 PM
JB400's Avatar
JB400 JB400 is offline
Looks pretty good. If you want to share this build with some other Aussies, send me a pm.
Old 01-05-2016, 05:58 PM
66fury's Avatar
66fury 66fury is offline
More more more pleeze !!
mark
Old 01-05-2016, 07:44 PM
hackster's Avatar
hackster hackster is offline
Amazing work.
