Old 01-07-2016, 01:13 PM
JKnight JKnight is offline
Default 69 Camaro Door Panels
Hi everyone. I'm trying to identify a supplier/manufacturer of a good quality replacement deluxe door panel for my original deluxe interior car.
I already have one repro set that are total crap and will never work right due to being too thick, so I need to know which brand/source has something that is proven to actually fit. I am familiar with the challenging process of getting them lined up right, so I expect that a good set will still require a good bit of work.
Old 01-07-2016, 02:00 PM
Musclerodz's Avatar
There is only 2 that I know of. OER and al noch. I have used several Al Noch sets and did not have any major issues. Where are your too thick?
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-07-2016, 04:52 PM
Thanks Mike.
The set I have are a black ABS plastic back, with black high density foam under the vinyl. When you hole-saw through the panel to create the path for the window crank, it becomes obvious how crazy thick these panels are compared to my originals (probably 1.5" of foam). As a result, the window crank handle can't reach through the panel to the stud. And yes, these are deluxe regulators. I've only swapped the drivers so far and am leaving the original passenger panel in place (it's in decent shape) until I can find a panel that fits well on the drivers side.
Old 01-07-2016, 10:35 PM
fishface's Avatar
fishface fishface is offline
If the backs on the original panels is in good shape maybe you could have them refinished. At on time Al Knoch did this and maybe Just Dashes. Something to consider.
Old 01-08-2016, 07:54 AM
Musclerodz's Avatar
you answered my next question on the regulators. However the handles fits fairly tight and can be a pain to get on, but I have always been able to get them on.
Mike Redpath
facebook page
Old 01-08-2016, 08:17 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I used AK. Real PIA to install as they were curved and the clip holes don't line up. Holes I understand as the door may vary somewhat.
Took a full day on each panel with a heat gun and hole reworking.
They do look great installed and I had no issues with the handles
Old 01-08-2016, 09:09 AM
That's interesting. Mine are "curved" as well. I assumed that was a shoddy trait unique to mine as well. They do seem to flatten out once installed though.
I've been able to work around the other issues but the splines of the window crank are probably 3/4 of an inch away from the stud. Had I not already cut the hole for the crank I guess I'd be going power windows! lol...
Old 01-08-2016, 03:19 PM
dhutton dhutton is offline
I have seen window crank extensions somewhere. Might be worth a google search.
Don
Old 01-08-2016, 07:06 PM
Ok, so there's really only two manufacturers. That helps. I'll take some pictures this weekend when I take it off to mess with the alignment some more. Will also measure the thickness so maybe someone can compare it to theirs.
Old 01-08-2016, 07:20 PM
Musclerodz's Avatar
Are you SURE you have deluxe regulators?
Mike Redpath
facebook page
