Old 01-07-2016, 02:20 PM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Default 67-81 Camaro / Firebird - RIDETECH'S NEW StreetGrip Suspension Package
This kit is the most advanced, complete, affordable and all USA made kit on the market. It offers the best ride quality of any suspension system available. It will work with your stock 14"+ Wheels too! This is an easy one day project that will transform your stock or modified muscle car into one you ENJOY driving, with a comfortable ride and great handling, all from a kit that comes in ONE box!
1967 - 1981 Camaro / Firebird Kit Includes:
(2) Front Progressive Rate Powder Coated Coil springs (Approx 1" drop)
(2) Rear Composite Leaf Springs with Billet ends (Approx 1" drop)
(4) Ridetech HQ - Single Adjustable MonoTube Shocks - Million Mile Warrantied
Front Heavy Duty Sway Bar with Delrin Frame Bushings and End link Kit
(8) Delrin Front Control Arm Bushings - Upper and Lower
(12) Rear Leaf Spring Bushings and shackle kit
(2) Tall Upper Ball Joints
This is due to the ultra high quality Ridetech/Fox Billet MonoTube Shocks, which are the HQ - Single Adjustable series, allowing you to dial in the ride quality to suit YOU!
The USA Made Hyperco Springs in this kit are a "Progressive Rate" meaning when you are cruising down the road, you are riding on the softer part of the coil. As the coil is loaded up (cornering) it gets stiffer to help keep the car level and in control.
The Hyperco composite leafs reduce unsprung weight by 50lbs! This improves ride quality and handling as well.
The new heavy duty Powder Coated front Sway Bar has been tuned perfectly to the rest of the system. It includes new Delrin frame bushings and new end links as well.
The Taller Upper Ball Joints play a major role in this kit. The stock suspension geometry in our cars was horrible! There was far too much "Positive Camber" in the system. This caused the tires to roll out in a turn, giving you much less tire contacting the ground, who wants that?! The height of the spindle was a major contributor to this. By swapping in a taller upper ball joint you increase the distance from the upper and lower control arms, this will reposition the control arms to correct the camber curve, giving you a much more stable and enjoyable driving and cornering experience.
The (8) included Front, Upper and Lower Delrin Control Arm Bushings are a major upgrade as well. The OE rubber bushings allow too much deflection on the arms. Poly will resist smooth rotation and impose stiction. Delrin eliminates these issues, leading to a huge improvement in both ride quality and handling.
The Rear Leaf Spring Delrin Bushing kit includes all 12 bushings you need for the frame, the rear of the leafs and the front of the leafs. It also includes new shackles and sleeves! These offer the same benefits as the front Delrin bushings do!
From Ridetech:
Go to any car gathering in America...for every 18" wheel, 14" brake, 600hp LS engine, 6-speed transmission car you see, there are 300 musclecars there with 15" rally wheels and white letter tires. These hot rodders enjoy their cars every bit as much as any other "race oriented" enthusiast does...but maybe in a different way. The StreetGrip customer likes to fire his car up a couple times a week to drive it to work...make an appearance at the local Cars N Coffee gathering, or maybe just take a weekend cruise. They want it to be smooth, reliable, nimble...and FUN to drive! RideTech has been focused on creating suspension systems that address a wide variety of hot rodders...Street Rods...Sport Trucks...Musclecars...and Racing. We have taken that 20+ years of engineering, racing, and market experience and developed a simple suspension system that is easy to install, rides wonderfully, and provides SERIOUS handling improvements while accommodating that battlefield we call the STREET. The performance criteria for the StreetGrip system is as follows...in order of importance:
Ride Quality -- EVERYONE is concerned about ride quality...ALL the time. If it does not ride good, you'll never drive it enough to appreciate the good handling!
Handling -- We have optimized the handling characteristics not for competition tires, but for real-world street tires that will see thousands of highway and backroad miles.
Ease of Installation -- No cutting...no welding...no fabrication...no modifications to fuel lines, brake lines, or exhaust. The StreetGrip system is a DIRECT replacement for your OEM suspension components.
Complete System in One Box -- No worries about compatibility of various components...nothing else to buy.
Composite Rear Leaf Springs
Why? 70lb weight savings in unsprung weight will improve handling and ride quality. These composite leafs also incorporate more torsional strength so any "spring wrap" is eliminated.
Dual-Rate Coil Springs
Why? A dual-rate spring will allow the vehicle to transition small road irregularities via a compliant spring rate. When the vehicle compresses the spring far enough (through large bumps or cornering), it transitions to the firmer spring rate to control the bump or body roll. This is a common concept in the OEM world to achieve the best combination of ride quality and handling characteristics. It is much less common in the aftermarket because of the time required to calculate and test the various combinations. RideTech and Hyperco have invested this engineering time to make sure we achieve optimum performance.
Delrin Control Arm bushings to fit your OEM control arms
Why? OEM rubber bushings allow too much deflection on the control arms. Poly bushings resist smooth rotation and impose stiction. Delrin bushings eliminate the deflection AND the stiction leading to a huge improvement in both ride quality and handling.
Taller Ball Joints
Why? Most OEM front suspension geometry, in addition to being designed over 50 years ago, induced "positive camber" when cornering (loaded tire leans away from the turn). This is a huge compromise in cornering performance and feel. By installing a taller set of ball joints, we reposition the control arms to correct this condition and create a much more stable and enjoyable driving and cornering experience.
Larger Front Swaybar
Why? Most OEM front swaybars were calibrated with tires and cornering loads that were radically less capable than today. We increase the diameter of the swaybar to minimize the body roll through the corners to optimize the handling performance.
Delrin Swaybar Bushings
Why? Similar to the control arm bushings, OEM rubber swaybar bushings allow too much deflection and poly bushings impose too much stiction. RideTech's exclusive Delrin-lined poly swaybar bushings offer the best of both worlds...minimal deflection and virtually zero stiction. Ride quality and handling performance are greatly improved.
Adjustable RideTech Monotube Shocks
Why? Shocks are the brains of your suspension...the single most important influence on ride quality and handling performance. RideTech and Fox have spent years refining the subtle valving characteristics of these monotube shocks to optimize the performance of YOUR car!
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
Old 01-13-2016, 10:47 AM
MCB Matt's Avatar
We just wanted to remind everyone, today is the last day of our New Years Sales. Give us a call for the fastest way to purchase, or send an Email/PM and we can send a Paypal invoice.
Thank you very much for the business this year already!
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 02-03-2016, 01:20 PM
MCB Matt's Avatar
Happy Hump Day to all, we are half way through the week!
We have now started our Tax Return specials of the week which will run until the end of April.
If there is something specific you need, just let me know and I will get you the best sale prices.
Thanks for your business out there!
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 02-11-2016, 02:24 PM
MCB Matt's Avatar
Thank you all for the orders, we appreciate your business!
Let us know if you need anything you don't see on our current website, the new one will have a LOT more!
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 02-12-2016, 03:19 PM
MCB Matt's Avatar
Here are some pics and ride height numbers for you guys! We will be installing this kit on our new 66 Chevelle Convertible in the next few weeks.
This gives an example of tire sizes vs ride height:
1969 Camaro
F - 235/45R17 R - 275/40R17
Ride Ht F - 24.25-24.75″ R- 24.5-25″
1970 Camaro
F - 245/45R17 R - 275/40R17
Ride Ht F - 24.75-25.5″ R - 26-26.5″”
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 02-18-2016, 01:10 PM
MCB Matt's Avatar
Thank you all very much for the business. It is crazy busy here, we have quite a few sales running now so let us know what you need and we will get you hooked up.
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 03-21-2016, 02:24 PM
MCB Matt's Avatar
Happy Monday to all!
More and more of these systems are making their way onto cars now and the feedback has been great! We just installed a kit on our 66 Chevelle, the ride comfort and handling is SO MUCH DIFFERENT! This was a bone stock SS clone, frame off restored car when we installed the kit. Other than the stock steering box and huge steering wheel, the car because much more comfortable and flat.
We would like to thank everyone for the response on our current Tax Time Sale! This covers just about everything we sell, give us a call, PM or Email for your sale price.
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 05-13-2016, 12:22 PM
MCB Matt's Avatar
Our 15 year anniversary is just a month away! It has been a long and interesting journey!!
We would like to offer up some of the best pricing we can for you guys! We have made many friends and regular customers over the years here. We truly appreciate the business and friendships.
Let us know what you need, we surprise a LOT of customers that had no idea we carried a particular brand they needed. It never hurts to ask! If it's a brand we don't offer for a particular reason, we will be honest about why.
We have earned the trust of so many on this forum, we have never ripped anyone off, played cut throat games with some of the "interesting" vendors here, some have come and GONE..
Thanks from all of us at MCB Parts
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 06-23-2016, 12:44 PM
MCB Matt's Avatar
Thank you all for the business on our anniversary sale. There is still another week left to jump in on this deal. Every brand we offer is covered in this sale, so basically anything you need for any build!
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 07-26-2016, 01:49 PM
MCB Matt's Avatar
Thank you all for you constant support, we appreciate your business and look forward to doing more, as well as meeting many new customers here.
Please let us know how we can help with your project. We do it all, A-Z!
MCB Parts
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
