Old 01-08-2016, 03:23 PM
elwaupo elwaupo is offline
Default 2005 8.1 Vortec
Does anybody have information on this motor? I have a chance to get one for a steel but I was thinking of an LS1 or LS2 but this came along
Old 01-08-2016, 04:40 PM
SSLance's Avatar
SSLance SSLance is offline
The 8.1 in my 2002 truck has 210,000 miles on it and I love it. It's basically a tall deck, stroked, 454 with Vortec heads, a one off intake manifold, and coil on plug electronics. Mine is an earlier one and does not have a crank case vent set up, so it has always sucked a little oil into the intake...usually uses about a quart every 800 miles or so (worse with synthetic oil).
It's a truck engine in it's stock form, so it builds huge torque down low and not a lot of upper end HP. They are used in marine applications and generators a LOT. When they decided to quit making them, Kohler bought all of them they could. Mine gets 11 mpg...pretty much no matter how I drive it. It'll get just under 10 MPG pulling a trailer down the highway at 80 MPH.
Is it good for a car? I'm sure it would be fun but the only ones I've seen transplanted had the throttle body sticking out a hole in the hood as they are very tall. What do you know about the history of the engine? Hoe many miles on it? Do you want to sell it?
Lance
Old 01-09-2016, 03:53 PM
jhiphopjunky's Avatar
jhiphopjunky jhiphopjunky is offline
I have a complete 2004 8.1 with an Alison 1000. 77k miles, all ecu's, wiring harnesses and gas pedal are included. I even have the original gauge cluster. Call or text me for more info. (707)294-4223 -James
