Old 01-13-2016, 11:31 PM
Yenko68 Yenko68 is offline
Default 6L80E drive shaft help
Can someone tell me how to get a drive shaft made to work from a 09 G8 GT into my 70 Nova? The factory one does not have the typical u joints at each end. Either I need to modify the factory one or figure out how to modify the tail shaft to accept the typical style shafts. Anyone dealt with this already?
Old 01-14-2016, 11:16 AM
Vince@Meanstreets's Avatar
if you have the G8 shaft you can have a drive shaft shop make one to fit the Nova using the parts from the G8. my local shop does it for about $250
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-14-2016, 11:32 AM
dhutton dhutton is offline
The Drive Shaft Shop can set you up. I had one made with a CV joint.
http://www.driveshaftshop.com
Don
Old 01-15-2016, 08:27 AM
Would I have to change my tail shaft flange since the rear of the G8's 6l80E has a 3 flange bracket and not a yoke ?
Old 01-30-2016, 05:53 PM
crestronwizard crestronwizard is offline
That's who we use too. They supply a shaft with the flange that bolts up.
Old 01-31-2016, 12:27 PM
I thought I'd just cheer somebody else (besides me) using a 6l80. If you have a local driveshaft shop, they can do anything you need, especially if you bring them sufficient evidence of what is there, along with specific measurements. Here's a cool link for measuring necessary length from the shop that made mine (to link the 6l80 to my C4 Corvette rear): http://www.dlssac.com/php/trig2.php.
