Old 01-14-2016, 03:40 PM
Try2paz's Avatar
Try2paz Try2paz is offline
Default Seals-it help??
Hey guys need to order up a new set of seals-it for my 9" and having a hard time finding the right seal.
It's a Currie 9" and the axel tubes at the base are 3.25" and reduce down to 3" teh wall looks to be .188 thick.
That would show an ID of 2.874 on the 3.25 section and 2.624 on the 3" section toward the hub.
Ideally id like to find a seal towards the base. We had a set of AS9188 on the shelf and to no surprise they are to small.
The next size up is AS9125
Silver AS9125 2.750" 2.720" Buy It Now
http://www.sealsit.com/axle-seals.html
I’ve tried john and he is out racing and trying to get these ordered before the weekend
any ideas?
1967 Nova
2018 Camaro ZL1 1LE
Old 01-15-2016, 12:30 AM
DBasher's Avatar
DBasher DBasher is offline
I've got the EAS1-5 that I'm not using, yours if you want them.
Let me know.
Old 01-15-2016, 10:28 AM
Try2paz's Avatar
what size ES5?
I might just take you up on that
1967 Nova
2018 Camaro ZL1 1LE
Old 01-15-2016, 11:10 AM
DBasher's Avatar
http://www.sealsit.com/economy-axle-...s15-group.html
From the economy series, although they look a bit different then what's pictured on the web site. I'll measure the actual size when I get home and if you need em they're yours. What I do know is I ordered them for my big bearing 9" with 31 spline Currie axles.
I talked with Mike this morning and will get that deal squared away with Bri this afternoon, sure appreciate that.
Old 01-15-2016, 12:13 PM
Try2paz's Avatar
thanks for the offer, I spoke with seals - it this am I had to use one that is a size up so I ordered a pair. they might still be to small but figured for $75 it was worth a try. If not were going to put in some baffles and call It good.
no problem on the seats enjoy!
1967 Nova
2018 Camaro ZL1 1LE
Old 01-15-2016, 01:42 PM
Nativefx Nativefx is offline
These aren't from seals-it, but these are the one's i bought and used for my 9" rearend with 3" axle tubes. I know they have other sizes, just not sure about the ones your looking for.
http://www.amazon.com/gp/product/B00...ilpage_o04_s00
