Old 01-21-2016, 11:59 AM
Neil B Neil B is offline
Default Roll Bar/Cage Tubing Material, Diameter and Wall Thickness
For you track-oriented guys, what tubing material, diameter and wall-thickness did you pick for your roll bar or roll cage? For a 3,000 lb. car, current SCCA/NASA rules seem to require 1 3/4" x .120" tubing regardless of whether it's mild steel or alloy. This is compared to the NHRA spec of 1.75" x .118" mild steel or 1.75" x .083" 4130 alloy.
Old 01-21-2016, 12:12 PM
SSLance's Avatar
SSLance SSLance is offline
The guy that built my 4 point bar made from it from 1.75" OD 0.120" wall mild steel. Said it was good for everything SCCA related up to actually door to door racing (no door bars or front hoop).
Lance
