Old 02-01-2016, 05:00 AM
AB69Z AB69Z is offline
Default Transmission selection & associated components-vendor selection
Ready to order a T56 for my 69 Camaro project. My full DSE suspension is going in right now. I have lots of questions here. And am really looking for the expertise from this site
- do I order one from the local GM dealer (if so is there one in particular) or do I order from a vendor like Bowler?
-Bell housing GM or alternate (differences between them)
- Clutch type ? GM LS7 clutch, Pressure Plate , Flywheel, All Bolts , Pilot Bearing
- Slip Yoke
- GM Transmission mount
- Crossmember which I know is aftermarket
- Transmission Tunnel panel which is aftermarket
- Shifter
- Drive Shaft, steel or aluminum, what's the difference?
Whatever I can order from the GM dealer should be helpful to me on these parts selection
Old 02-01-2016, 09:47 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
There are a lot of different choices here.
What engine do you have? Horsepower level?
GM only sells the T56 Super Magnum. It is MSRP'd at over $4,000, as compared to the Tremec T56 Magnum at $3050.
If you're under 650hp the GM LS7 clutch is a good one.
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 02-01-2016, 12:29 PM
I'm going to run the GM LS3 525 Hp motor
Old 02-08-2016, 02:43 PM
Ron@HDC's Avatar
Ron@HDC Ron@HDC is offline
We have recently redesigned our website to help make the process of selecting components for your transmission swap fast and easy. Simply enter in the year, model, planned engine and console configuration of your vehicle and then select or deselect parts according to your needs.
You can find our transmission swap kit builder for GM vehicles by clicking this link.
If you have any other questions, don't hesitate to give us a call at 707-535-3030.
