Old 02-03-2016, 05:19 AM
AB69Z AB69Z is offline
Default Transmission Crossmembers
1969 Camaro with a DSE subframe and T56 transmission.
What are my options for the crossmember?
I'm concerned with keeping the exhaust up as close to the floor pan as possible.
I really like what DSE does on their custom builds as it's all built directly into the tunnel, but unfortunately they don't offer these components
Old 02-03-2016, 05:39 AM
Hooker has a very nice piece. I have one in my car and it fits very well. Big openings for exhaust to pass through.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 02-03-2016, 06:16 AM
rickpaw rickpaw is offline
Actually DSE does sell their version of the T56 crossmember, but it's quite spendy.
http://www.detroitspeed.com/1967-196...ossmember.html
Tu Ho
Old 02-03-2016, 08:11 AM
Does it bolt right up to the DSE subframe?
Can a GM transmission mount be used on it or does it require a special one?
What type of headers did you use ?
Are there any other issues that will be encountered?
I like the way it looks over the Bowler mount I was looking at
Old 02-06-2016, 09:11 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
What engine you gonna run? I'm running a SBC with my T56 Mag in the DSE subframe. I used a GForce crossmember that was supposed to fit but it required a lot of fabrication to make it work. Unless you have a welder and some fabricating skils, I would not recommend it.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 02-07-2016, 04:52 AM
Going to run the LS3 525hp crate motor
Old 02-07-2016, 07:58 AM
Mine bolted right up with no issues.
I had an energy suspension mount that didn't seem to fit (wouldn't sit down in the pocket of the crossmember). I did some research and saw it required a specific Prothane mount. I will be putting my engine/transmission back in my car in about 2-3 weeks, and haven't tried that mount yet, but will let you know soon. Worst case I may have to slot the holes slightly to bring the crossmember further forward in the car by about 1/8-1/4".
My car is a turbo car, so headers wouldn't be applicable to you. I have stainless works up/forward turbo headers that have been modified.
Other issues mentioned above, mount is specific and dependent if mount makes it fit perfect I MIGHT have to slot the mounting holes.
I really like the looks fo this one too and it really does give a TON of room for exhaust to route through it. I have 3" exhaust through mine and there is room to spare.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 02-07-2016, 01:08 PM
minendrews68 minendrews68 is offline
I've got the same crossmember. I have a SBC coupled to a T-56. I had to alter mine, but I can't think of a better one, I really like it.
Old 02-07-2016, 01:39 PM
randy randy is offline
ls3/t56, stainless works, dse subframe and i had to alter mine. I moved it closer to the front of the car and also had to remove a a lot of metal bc it hit my headers.
