Old 02-08-2016, 02:51 PM
lnirenberg lnirenberg is offline
Default 1957 9 passenger Pontiac Safari
Item Location (City/State):Wayland, Ma
Price:$60k
Description:
Default 1957 9 passenger Pontiac safari
Out of the box tow vehicle-
1957 Nine-Passenger Pontiac Chieftain Safari Wagon
3,000 miles since completion...
Block: NEW SBC Roller Cam block, dynamic balance to match new rods and crank, Speed Pro Hypereutectic with moly coated skirts, Comp Cams Flat Tappet Camshaft (slight lump at idle), Edelbrock Performer intake with Holley 600 cfm shiny carb, electric fuel pump, MSD HEI Ignition, GM Serpentine frontrunner kit, Engine painted 1957 Pontiac Green.
700R4 transmission with toggle to unlock 1800 rpm torque converter, New drive shaft, New dual master cylinder, New coated brake lines, Rebuilt posi-rear end, new axles, hubs, bearings and drum brakes. Front and rear sway bars, New heavy duty springs and shocks including rear air shocks, Custom 18 gallon SS gas tank, new ss gas lines. Prior owner stripped and painted car in single stage OEM Carib Coral, Replated bumpers and trim, Stainless polished and straightened, New or restored emblems, NOS light lenses, Halogen head lights with proper relays, New front Corvette hubs with disk brakes, new bearings
Power rack and pinion steering, Vintage AC, Custom 15” steering wheel, Custom gauges in stock locations including a new quartz clock. Under dash (mounted in original front speaker box) blue tooth, IPod feed and backup camera. New carpet, new OEM style seat covers and door panels and custom head liner with LED lights. New door handle and window cranks, new wing window frames and new window felts. All window glass replaced with original manufacturer tinted glass made in USA.
Larry
1957 Pontiac Safari
2014 911 GT3
2006 Ram SRT-10
2014 MB E250
