Old 02-12-2016, 06:03 AM
jlwdvm jlwdvm is offline
Default Starter spinning when key turned to ignition location?
Ls3 in 69 firebird with GM starter and AAW Power Plus 20 rewire of complete car with battery in trunk is the project. I was checking a few areas for power before I do my first start up and noticed a problem. My GMTILT column key switch can be moved forward 3 times (first click, second click (ignition) and all the way forward (starter). The first click forward gets me no power to any of the ignition areas (this must be available so the steering wheel will unlock to be able to steer the car (mine has the lock removed anyways). When I move the key forward the second time that should get me 12 volts to ignition hot areas the starter kicks in and the motor starts to turn over. Do I have some wires switched around? Thanks!
Old 02-12-2016, 07:06 AM
dontlifttoshift's Avatar
All the way back is accessory.
Next click is off.
Next is ignition run.
And the last one is Start, it is spring loaded.
That ignition switch is adjustable up and down the column.
Donny
Old 02-12-2016, 07:17 AM
Woops...looks like I'll have to recheck things! I did have the ignition switch off of the column when I was wiring the car. Is there a trick to getting it adjusted right?
Old 02-12-2016, 10:38 AM
Im sure there is but I don't know it. A quick goggle search should turn something up.
Donny
Old 02-13-2016, 07:31 AM
I checked a few things. I have power at "Battery" locations throughout the wire harness; my headlights don't work; and I still have no power when the key is placed in the "Ignition" location with the key (1 click forward or backward). The headlights is probably an easy fix (hopefully), but the ignition power has me scratching my head.
Old 02-13-2016, 08:17 AM
Wiring is EXTREMELY difficult to diagnose over the internet.... But there are things you can do to test and to isolate an electrical issue.
#1 - You need a volt/ohm/continuity checker of some kind
#2 - You have to understand how to use #1
#3 - You have to understand that electricity is a CIRCUIT which consists of BOTH negative and positive connections.
#4 - You check (and label) one wire at a time
#5 - A "switch" is a circuit "maker" or "interrupter" - but that switch only makes a "break" in one side of the circuit. In other words - a wire coming in to the switch is 12V POSITIVE - then the wire going OUT is also 12V POSITIVE. A switch is not a junction box. A switch should/could have a 12V NEGATIVE terminal to ground it.
I mention the switch because you're having ignition AND headlight issues. Tends to make me think there is a SWITCH wiring issue.
Let's deal with the headlights first since they're easy and might help you understand where your wiring is "messed up" (if it is)
Headlights typically have THREE wires leading to them -- Low beam - High beam - Ground. But there are TWO switches. One for turning on the low beam and a foot or stalk operated switch to operate the high beam.
For the moment - let's forget about the high beam and just see if the headlight switch is going to operate.
Remember that the dash switch is just going to switch the 12V POSITIVE.... as the headlights should have a black 12V ground wire - grounded to the chassis/bodywork/core support close to them.
The headlight SWITCH may or may not get the 12V power from the ignition switch (I'm not sure what your wiring system and switches are). Which may be your issue. No power from the ignition switch means no power to the headlight switch.
SO ------- Take your voltage tester and see if you have 12V + Power to the INPUT side of that switch. IF you don't have voltage there -- then you have to trace that INPUT side of that switch - see where that power is SUPPOSED to be coming from. Because one side of that switch is 12V in and the other goes "out" to either the floor switch or the stalk switch in order to run the lights. But you must also check to see that the lights are GROUNDED or you won't have a circuit. AND most likely - your SWITCH needs to have a ground.
Here's the best photo I could find of a GM headlight switch. FIND the red 12V POSITIVE input and see if you have 12V there. Also check that it makes a circuit between the ground (using your continuity function of the tester) GROUNDS are the most overlooked part of an electrical system. For whatever reason people just don't give them any attention and think they're just there for looks or something. When I make a ground connection I ALWAYS use a star washer UNDER the ground lug of the wire. A star washer goes between the attachment point (say the frame or fender) and the wire lug - they're used to CUT thru paint and get to bare metal in order to make good contact. I see people using them like a lock washer all the time - and that's WRONG.
This DIAGRAM may or may not be your switch -- if it's not - then GOOGLE a wiring diagram of YOUR switch so that you can see what it is you need to test..... I just pulled this one (common) off the net.
Just do that simple check and report back....
Old 02-13-2016, 08:43 AM
The other issue I'd be looking for is do you have the GM Starter Interlock / SAFETY switch installed (or installed correctly). I think you said you have a column switch - which leads me to think you're trying to use a "factory" style harness and electrical connections.
Here's the neutral safety switch -- it's not going to let you start the car if it's not wired correctly. It should look like this or something similar. Again - you may need to find a wiring diagram specifically for your situation.
Old 02-13-2016, 09:25 AM
Che70velle's Avatar
Great information Greg!
When doing a diagnostic check, as is the case here, I always start at the fuse panel. Turn the key to run, or on position, and with a volt meter (one probe of meter to fuse, the other to a good, clean ground) check BOTH sides of every fuse in the block first. This ensures me that 12 volts is in fact making it to the switches, and then as Greg described above, go from there.
A fuse will usually tell you that you've got problems, meaning mis-wiring, by blowing. If no blown fuses, 99% of the time it is a grounding issue.
Thanks Dad!!
Old 02-13-2016, 09:37 AM
Thanks for the great write up Greg! I am hoping to get some garage time today. Here is what I can tell you so far:
The I am using an AAW Power Plus 20 wiring kit.
The Headlights are grounded on each side to a bare metal area on my bumper support. I used dielectric grease at all chassis ground points. The battery is grounded to the frame in the trunk, the motor is grounded to the sub frame, and the rad support is grounded to the sub frame as well. I am also using solid aluminum body mounts.
My head light switch looks like the picture you showed. It has 12 volts going in to it (verified with a test light). It is not attached to anything yet since my fabricated dash is out of the car while I finish up the under dash work (switch not grounded could be a problem?).
I do not have a neutral safety switch wired into the harness, but it is shown in the AAW wiring diagram. I'll have to double check starter wiring. I believe I have the LS starter wire running directly from the starter pig tail to the ignition switch (purple wire).
I have 12 volts to the fuse panel. I checked several open "battery" tabs with my test light. I also tested the auxillary pig tail that AAW places in the harness for misc battery or ignition sources that may be needed with a particular car. I have 12 volts to battery tabs and nothing to ignition source tabs.
Old 02-13-2016, 09:46 AM
Okay --- SO that PURPLE ignition wire should have NO POWER to it unless your ignition is in START (spring loaded) position. That small gauge wire just runs to the solenoid to make it engage.... the actual motor gets it's power from the big ass gauge wire from the battery which runs the big starter motor.... (In essence - the starter purple wire is like operating a relay but I don't want to confuse you).
