Old 02-12-2016, 07:07 PM
n77nxc's Avatar
n77nxc n77nxc is offline
Default Seepage or Leak?
I was recently under the car doing some exhaust work and noticed a film of oil on the bottom of the oil pan and the bell housing of the transmission.
First off, this is a brand new LQ9 engine with a Holley LS oil pan installed. Its never dripped one drop of oil on the garage floor, and I have roughly 600 miles on the car.
I'm hoping this is an oil pan gasket issue and not something more serious like the rear main, but I wanted to run it past you guys to get some input.
Here are some pics:
1967 Camaro - Project "Resale Red" - Sold to 175RGR
Old 02-12-2016, 07:19 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I just finished installing a used LQ9 in a 69. It did not leak a drop. Shortly after I stallng and running (not driven yet) I have a leak similar but more severe then yours.
I've checked everything possible and have determined it's most likely rear seal.
Will be pulling the tranny to confirm
Old 02-12-2016, 07:31 PM
n77nxc's Avatar
The thing that gets me is the seepage area around the parameter bolts for the oil pan. That's the part that makes me think its a gasket issue. Guess I'll just have to dive into it a little more.
Good luck on finding out whats causing your leak.
Old 02-16-2016, 02:27 AM
71RS/SS396's Avatar
Did you run a bead of silicone across the front and rear cover seams?
Old 02-16-2016, 05:55 AM
n77nxc's Avatar
Yes, I ran a bead over the seams.
I was able to shine a light up through the small notch in the transmission case and got a good look at rear main seal, and there doesn't appear to be any leakage there. I'm pretty confident I'm dealing with a gasket issue.
