Old 02-14-2016, 11:57 AM
69hugger's Avatar
69hugger 69hugger is offline
Default What is this hole for?
Can anyone tell me if this hole leads to the interior & it's purpose? I am referring to the 3 x 6 triangular hole in the cowl facing sideways in the center of the pic.
I reach into it & I think I can feel the Vintage Air box, but can't tell for sure. If it is the fresh air intake for the factory HVAC system, do I need it with a V/A unit?
I ask because this leads back to an issue with my car where on extended driving, (over an hour) on hot, humid days, I get condensation dripping from under the dash, coming from the A/C ducts.
If this is a massive air leak coming in under the dash, seems to me blocking this hole may be the answer.
Do I need fresh air coming into the car, or is recirculating & cooling what is in there & cracking the windows sufficient?
What about the similar hole on the drivers side? That seems to lead nowhere, but I can't tell for sure.
As always, thanks for the help!!
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 02-14-2016, 04:11 PM
Vince@Meanstreets's Avatar
If you drill a hole it goes to the interior. It's the back side of the firewall toe pan reinforcement.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-14-2016, 04:24 PM
My guess is -- if you take off your kick panels (the side panels down by your feet) -- the vent (they called it Astro vent) probably aren't sealed off well... the flapper vent in there needs to be sealed. Usually the rubber seal on those vents is all dried up and rotten - so even if they were closed - they'd still leak like crazy.
Old 02-14-2016, 09:21 PM
ilikeike's Avatar
ilikeike ilikeike is offline
I used that hole when I changed the sub to body cage nut.
I came in handy for that. Don't know what else you might need it for in the future.
Old 02-15-2016, 03:35 PM
69hugger's Avatar
Lazy me.... I dug around & realized the hole led nowhere. It was a false alarm. Too bad. I was looking for an easy solution to the under dash rain forest.
Oh well...
Bill
Old 02-16-2016, 07:23 AM
hifi875's Avatar
hifi875 hifi875 is offline
Oh well...
Dont they all leak? I thought all 69 camaros leaked atleast somewhere!
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 02-16-2016, 07:50 AM
69hugger's Avatar
I was referring to condensation from the A/C system dripping from under the dash, not a water leak.
Mine only leaks in the trunk from around the trunk gasket, although I think I got the right gasket finally to fix it. Here's hoping...
Bill
