Old 02-20-2016, 07:48 AM
jeff hanson's Avatar
jeff hanson jeff hanson is offline
Default mini tub on a budget
Hello again, it's been a while since I've been here but some of you might remember my Tech 9 Camaro back in 08/09...
Anyway, I've been more in the motorcycle scene for the past 5 or so years but the bug just bit me again to do another car. I pulled the trigger a couple days ago on a clean, mostly original 69 again. However, this one is going to be a lot more on a budget than the last one. I'm looking for some guidance on the least expensive route to mini tub the car. As I said, I've been away from the scene for about 5 years for all intensive purposes so I need to get up to speed again. I originally was thinking of just moving the leaf springs in but after looking at a few things, it looks like by the time it's all said and done, it's hardly any different to put a 4 link in the car. I just don't want to put the wrong 4 link in just because it's cheap. I have no problem just sticking with leaf springs and offset shackles if it saves a bunch of money. It's just going to be a cruiser with either a small block or possibly an LS2/LS3 if I can find the right deal. Again, just trying to get some input on the most economical way to get this done because it's the one must have on the car...
Thanks for any input you can offer!👍
Old 02-22-2016, 08:39 AM
MaxHarvard's Avatar
If you want to mini-tub the car, the cheapest way is to do it yourself.
It's not an expensive job to do, just very labor intensive. If you've ever done it, it should take roughly 40-50 hours. If you haven't done it, expect 60+ hours. Ask me how I know?
Here's a how-to guide.
http://gearheaddaily.com/dat-ass-how...-in-your-ride/
Old 02-23-2016, 01:03 PM
BMR Sales's Avatar
Yes, it's at least a 40 Hour Job!
Old 02-23-2016, 04:06 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
What they said. Tubs cost about $150 but labor will eat up the vast majority of the expense. If you do it yourself they are not technically difficult to install, just time consuming. There are a lot of threads on here and Pro-Touring.com showing the step by step process. Keep this in mind however, when you install the tubs you notch the frame rails and this may cause flexing if you keep leaf springs. With a 4 link such as Ridetech this frame notch is not an issue as the load is supported by a weld in saddle.
http://www.ridetech.com/store/1967-1...rd-airbar.html
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 02-23-2016, 06:15 PM
MangeMD MangeMD is offline
I'll be attempting the DSE mini tubs on my 68 Camaro this spring. Should be interesting to say the least lol.
Old 02-23-2016, 06:21 PM
JKnight JKnight is offline
There may be quite a few of us giving it a go at the same time. May have to form a support group!
