Old 02-20-2016, 06:39 PM
Nitrous Nitrous is offline
Default T56 Magnum Stock Shifter
Does the stock shifter that comes with the T56 Magnum have springs to center it like the aftermarket shifters do or not really compared to them? I'm hoping that when in second I can just slam it forward and have it go into 3rd.
Old 02-23-2016, 04:25 PM
Ron@HDC's Avatar
Ron@HDC Ron@HDC is offline
Yes. The Tremec shifter that comes standard on the T-56 Magnum does have centering springs.
Old 02-23-2016, 09:42 PM
Sieg's Avatar
Sieg Sieg is offline
Though by no means is it a Hurst Blackjack. Which is worth every penny considering the amount of contact time you have with it......IMO.
Old 03-02-2016, 09:08 AM
GMJim's Avatar
GMJim GMJim is offline
We share that opinion! Nice shifter!
Old 03-02-2016, 09:45 AM
paulk68 paulk68 is offline
did they fix the leaking issues with the "black jack" I read alot of people were having issues a while back
Old 03-02-2016, 11:57 AM
GMJim's Avatar
Yes fixed. The shifter only leaked if it was in the forward position over the gear below on the Magnum.
Old 03-22-2016, 09:34 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
I can guarantee that if you "just slam it forward" into 3rd with the Tremec shifter you will end up in 5th every time. That is NOT the correct way to shift a T56 Magnum. I learned that your shifts are much more positive if you shift with your finger tips.
The stock Tremec shifter has a centering spring but it will not lock out 5th when shifting to 3rd. Personally, I am holding out for the S1 sequential shifter.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 03-27-2016, 10:06 PM
gnx7's Avatar
gnx7 gnx7 is offline
I have been emailing the guys at S1 about a Magnum shifter offering and that was months ago. Hopefully they finish something up this year.
That would be really slick.
