Old 02-21-2016, 03:00 PM
Painter D's Avatar
Painter D Painter D is offline
Default 69 Nova LS oil pan question
Anybody know if any OEM oil pans will fit nicely and will not hang down too low on a 69 Nova with LS swap? Or am I going to have to aftermarket or homemeade?
The car is going to be extremely low so ground clearance is a big issue. Any help would be great, THANKS
Old 02-21-2016, 04:45 PM
Not sure if it fits your bill but I have a 302-1 Holley pan with oil drains I need to part ways with. Touched the rack on my DSE frame so went with MAST.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 02-22-2016, 08:37 AM
MaxHarvard's Avatar
MAST and Holley both make good swap pans. Same as a Camaro for your Nova.
MAST is baffled.
Old 02-22-2016, 12:08 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Will
Check your messages.
MAST is baffled.
Jim
Old 02-29-2016, 10:15 AM
IndyNova's Avatar
IndyNova IndyNova is offline
I had the "muscle car" pan and it hung 3" below my cross member on my 69 Nova. I got the 302-2 pan with baffles and it fit like a glove.
https://facebook.com/Protour69Nova
69 Nova-Ridetech, LS
Old 02-29-2016, 03:15 PM
Che70velle's Avatar
Ok, Nova and Camaro in this case, being a 69' share the same subframe, correct?
Thanks Dad!!
Old 02-29-2016, 04:51 PM
andrewb70's Avatar
Holley not only makes a good pan but a complete swap system with all the components working together.
Andrew
Old 03-01-2016, 07:33 AM
IndyNova's Avatar
yes, same subframe.
Old 03-01-2016, 02:38 PM
Che70velle's Avatar
Originally Posted by IndyNova View Post
yes, same subframe.
I thought so. So....I'd run what the first gen Camaro guys are running. There are a couple first gen builds on here if you do a search...
Thanks Dad!!
Old 03-01-2016, 04:25 PM
Depending on your crossmember location, you might want to check into the F-body Camaro pan (GM parts). I found it to offer the greatest clearance of any, including the aftermarket pans mentioned above. I found a great deal on it (including the pan, windage tray, dipstick, filter, and all necessary gaskets/bolts) at some dealership in Kansas or Missouri. I wish I could remember the name of the dealer, but I think it was owned by a NASCAR guy whose name is escaping me . . .
