Old 02-21-2016, 08:18 PM
atomicjoe23 atomicjoe23 is offline
Default First-gen F-Body wheel to steering arm/tie rod end clearance???
How much clearance do you guys recommend from the inner wheel lip to the steering arm/tie rod end?
I'm ordering my wheel spacers/adapers tomorrow (hopefully) and I just want to double check on his before I order.
Thanks!
'67 Pontiac Firebird 400 RA coupe
http://www.pro-touring.com/forum/showthread.php?t=26557
'97 Chevy Camaro 3.8/M5 coupe
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
Old 03-08-2016, 09:45 PM
Bump. . .
. . .I ordered my wheel spacers; rears fit great. . .fronts would be fine except for the steering arm.
I'm gonna swap a rear spacer to the front which will put about a quarter inch of space between the rim and the steering arm. . .I'm gonna cycle the suspension between full bump and full droop at lock to lock steering to check for interference, but I wouldn't mind getting some feedback as far what you guys would consider minimum adequate clearance between the steering arm and the rim. . .
Thanks for the help!
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
