Old 03-07-2016, 02:32 PM
Mickav6 Mickav6 is offline
Default 1st gen Camaro front geometry?!
Is there any info on very precise mesurement of the front geometry and suspension for 1968 camaro? like some sort of a fisher data of the subframe but with suspension et geometry?
Old 03-07-2016, 05:22 PM
Build-It-Break-it's Avatar
http://www.pozziracing.com/first_gen_suspension.htm
Ahmad B
Old 03-08-2016, 05:10 PM
frojoe's Avatar
frojoe frojoe is offline
I've been in the process of 3D'ing my Nova subframe suspension to locate UCA/LCA/steering/spindles/etc to model everything, but there are some values that I want to reconfirm. For pivot points it's really quite critical that you get measure things within 1/8" or better for accuracy, and even then the variation from frame to frame can be pretty decent.
What values are you after in particular?
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 03-09-2016, 10:45 AM
mesurement between the control arm (lower /upper ) on both side, Ball joint to ball joint, Ball joint to ground! lol stuff like that!
