Old 03-09-2016, 07:22 AM
jlwdvm jlwdvm is offline
Default Ridetech front suspension and coil over install questions
I have the Tru Turn with strong arm and coil overs from Ride Tech installed on my 69 Firebird. I'm finalizing the install and have a few questions:
1. Is there an accurate/easy way to tighten down the ball joint nuts? It is hard to get a wrench on the nuts, let alone a torque wrench!
2. Is there a way to remove/install the coil over shock without disassembling the lower A-arm from the steering knuckle?
3. Is there a special tool to use to adjust the spring to set ride height?
Thanks!
Old 03-14-2016, 09:04 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Hey,
I'll answer your questions below!
On the ball joint nuts, I've seen some guys use a crow's foot attached to a torque wrench to actually get it to the proper spec. However, I personally have always just tightened the balljoint down and lined up the castle nut with the cotter pin, and been good to go!
If you remove the preload on the spanner nut, you can pull the lower bolt out of the shock. You should be able to remove the coilover without much of a battle.
Yes, there is. You should've received one with the coilovers. If you don't mind, PM me your name and order information and I'll get one sent right out to you!
Thanks!
