Old 03-09-2016, 07:41 PM
n77nxc's Avatar
n77nxc n77nxc is offline
Default eBay LS Swap Headers - Test fit on a 67 Camaro
I've been on the hunt for a set of headers to replace the Dynatech LT's I have on my 67. The Dynatechs hang extremely low, and I cringe every time I scrape them on something.
I ordered a set of eBay shorty headers awhile back based on a recommendation from a member here. I had my doubts about the fitment/quality, but for the price ~$175, it was worth a shot. After roughly 6 months, I finally decided to take the time and see if they would work.
I'm not here to argue about Chinese vs. American but purely to inform others about the fitment. They fit like a glove with my setup. I searched high and low to see pics of these installed on a 1st gen Camaro and turned up nothing. So here goes:
I only took pics of the driver side since most header issues involve clearance with the steering box. I have set back brackets on my car and if the engine was pushed forward, there could potentially be interference with the steering box.
Next up is to fab the downpipes. I'll post more pics once I get the downpipes installed.
1967 Camaro - Project "Resale Red" - Sold to 175RGR
Old 03-10-2016, 05:53 AM
Corey R. Corey R. is offline
Looks like they clear fairly well. How close is that tube on cylinder 7 to the 90 degree PS fitting? It looks close. I have seen some 1st gen folks have issues with fitment and long term durability with the long tube headers (67Rally comes to mind).
What material are these made out of?
Old 03-10-2016, 06:53 AM
n77nxc's Avatar
Its the angle of the photo. There is plenty of clearance there. I can verify the exact measurement.
They are stainless steel. Probably the cheapest type but we will see how long they last. This was more of an experiment, so I'm not worried about it.
I'm just glad to get the Dynatech's off the car. Those are a nightmare on lowered 1st gens.
Old 03-12-2016, 05:59 PM
I think I have these same headers on my Falcon (5.3 LS). It'll be some time before I get any heat in the headers, but overall, I was very impressed with the materials (flanges/thickness) and welds. I mainly bought them because the manifolds I thought I was going to use presented too many problems. An added benefit of the headers is decent weight savings. They fit the around the block and bellhousing like gloves . . .
Old 03-12-2016, 08:28 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I have been eyeing these up. Has anyone tried them?
http://www.speed-engineering.com/ls-...6-engines.html
Trying to get my buddy to give them a shot, as he has dynatechs as well with poor ground clearance. Shimming the tailshaft would help a ton, but he's running a t56 and it hits the tunnel. In the short term we are going to cut the collectors off the dynatechs & run a slip fit collector with a thin style band clamp.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 03-12-2016, 08:59 PM
n77nxc's Avatar
Those Speed Engineering headers closely resemble the Dynatechs. I can see those still having ground clearance issues.
Old 03-13-2016, 09:48 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
This the problem. On T56 tranny installs the tunnel needs to be cut to get proper driveline angle which also brings the header collectors level with the subframe and achieves more ground clearance. Also keeps the engine level in the engine bay and the rear of the engine parallel to the firewall and puts less stress on the motor mounts.
We have dynatechs on a 69 lowered 2" on Hotchkiss springs. Clearance work ok. I ran Hooker Supercomps on 2 cars and they tuck up nicely higher then the FBody oil pan.
Old 03-13-2016, 12:16 PM
Z06vette's Avatar
Ya, he needs to raise the tunnel. We'll do it eventually. I raised mine last winter during a motor & subframe swap with the alston chassisworks cap. For now we'll delete the collectors flanges to the slip fit style. There's only a few scrapes on the header tubes themselves, but the collectors are ground down a bit. Its still going to scrape, but at least it will be on a flat surfaces vs a vertical one.
69 RS LS3/T56
67 RS LS2/T56
Old 03-13-2016, 08:18 PM
n77nxc's Avatar
I checked the clearance and it's a little over an inch.
Old 03-18-2016, 05:41 PM
camarodude87's Avatar
camarodude87 camarodude87 is offline
Can you post a link of where you got your headers from. Im looking for a set myself for my 69 Camaro
