Old 03-10-2016, 09:02 PM
atomicjoe23 atomicjoe23 is offline
Default Fuel tank cleaning???
Any suggestions on a reasonable way to clean out a fuel tank that's been sitting for 15 years???
I already dumped all the fuel out. . .just wondering what to do before I reinstall the tank and refill it. . .
. . .I've already replaced all the fuel lines front to rear.
Thanks!
'67 Pontiac Firebird 400 RA coupe
http://www.pro-touring.com/forum/showthread.php?t=26557
'97 Chevy Camaro 3.8/M5 coupe
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
Old 03-11-2016, 04:39 AM
SSLance's Avatar
SSLance SSLance is offline
Back in the day, we used to lower a length of chain down into a tank and then rattle the tank around letting the chain knock anything that was loose or scaly inside the tank away from the metal. Then rinse and dump a few times.
Eastwood makes a gas tank recondition kit, basically you do the same as above but then put their sealer on the inside of the tank swishing it around to seal all inside surfaces.
http://search.eastwood.com/search?w=...20sealer%20kit
Lance
Old 03-11-2016, 05:19 AM
I've done the chain thing before on my old Massey Harris tractors. . .worked really well. . .LOTS of work, but it worked well.
This tank doesn't appear to have rust or scale in it. . .I was more worried about any residual bad gas or residue from the old gas leaching into the new gas I would put into the tank.
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
Old 03-11-2016, 06:13 AM
69hugger's Avatar
69hugger 69hugger is offline
Depending on the filler neck design, you could use a pressure washer or take it to a coin-op car wash & wash it out. Between the filler and sender ports, you can reach most of the inside. Use the soapy setting, swish it out, then rinse it. Do it for several cycles.
Then either set it in the sun to bake out the residual moisture, or hook a shop vac up (using the hose on the exhaust side) to the filler to blow it out.
I did this process with my stainless tank & after a few hours of airing out with the vac, there was no fuel smell. It needed welding, and this worked well.
Good luck!!
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 03-11-2016, 09:45 AM
OK. . .sounds like all the same stuff I've done before in the past with old/antique tractors. . .
. . .guess I'll be getting the pressure washer out this weekend.
Thanks for the suggestions!
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
Old 03-11-2016, 12:14 PM
djorgensen3 djorgensen3 is offline
Default Gas tank cleaning
I cleaned up an old hd sportster gas tank that had all kinds of crud in it by dumping in a couple thousand BB's and shook the heck out of it. It looked new inside when I was done. I also rinsed it several times in between with parts cleaner to clean the inside of tank and clean up the BB's. Did it probably 4 or 5 times.
Old 03-11-2016, 01:55 PM
Musclerodz's Avatar
I don't bother anymore. Depending on the tank I would just buy a new one and not worry about it.
Mike Redpath
Musclerodz & Customz
facebook page
