Old 03-20-2016, 05:03 AM
Default Fuel tank vent
Anyone making a fuel vent in the $100.00 range? I like the is much stuff but it's crazy pricey https://www.iimuch.com/collections/f...erential-vents
Other options ? I say a coy thread but I can't weld aluminum so kinda stuck
Old 03-20-2016, 07:32 AM
67machrod 67machrod is offline
http://www.tanksinc.com/index.cfm/pa...prod/prd98.htm
Old 03-20-2016, 08:28 AM
130fe 130fe is offline
Thumbs up Fuel vents
I have one of the original II Much vents and like it a lot. Others are using the Finch dual (fuel and rear) vents http://www.finchperformance.com/ Yeah, they are pricey but they work really well. I haven't heard too many good reviews of the tanks inc vent.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-20-2016, 12:29 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Tanks Inc recently changed the design of the EFI Tank to have 2 vents that plumb to the roll over vent.
I've installed 3 of them and 3 other guys I know recently purchased and installed them. No leaks, No smells in the garage.
I have one in my new car and top it off when I fill the tank. No issues
Old 03-20-2016, 01:45 PM
I have a ricks stainless tank
Old 03-20-2016, 05:04 PM
Hey John, the vent issues you had on your old black car, was that with the early design tanks inc tank? I thought Steve (who owns your old blue 69)had vent issues with that roll over valve in his car.
Chris
1968 Camaro SS
LS3/T56
Old 03-21-2016, 06:56 AM
Vega$69's Avatar
Tanks sent us a new tank at no charge for Steves car. It's now trouble free.
The issue was the vent port on the fuel pump module would be slightly below the fuel level when the tank was full. So if any pressure built up in the tank when it warmed up fuel could be forced out through the vent. Once your ran the tank down a gallon or so th fuel level was below the vent port and everything was ok.
Tanks added a vent port to the tank at the highest point so problem solved.
Old 03-21-2016, 09:32 AM
hifi875's Avatar
hifi875 hifi875 is offline
mine does the same thing. i have a tanks from 2013 and when i fill it up all the way it leaks. hmm
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 03-21-2016, 03:33 PM
Vega$69's Avatar
You can add a vent that ties into the filler neck. That's one solution or call Tanks.
Old 03-21-2016, 06:30 PM
Thumbs up
Good to hear you guys got that issue worked out, thats a pretty aggravating thing to deal with.
Chris
1968 Camaro SS
LS3/T56
