Old 03-23-2016, 08:39 AM
jy211's Avatar
jy211 jy211 is offline
Default Car Stalling / Fuel Starvation Question
Question for you guys:
Has anyone ran into a issue like this:
I'll take a ride through my neighborhood and the car stalls/shuts off sometimes, after a mild curve or left or right hand turn. Also sometimes after a curve, I'll hit the gas to make it up to a stop sign and the car shuts off?
The car does it at any fuel level in the tank. Car has a L92 FI set up.
I've sent the tank back to Ricks and they made a adjustment, but it's still happening.
Any suggestions?
Old 06-11-2016, 12:05 AM
camarodude87's Avatar
camarodude87 camarodude87 is offline
Had the same issue today. It might be vapor lock. I had to put a bag of ice on my ls6 intake. Might be the routing of your fuel lines. Make sure its not next to your headers.
I thought getting a nice fuel tank with a pump would solve that issue but I guess not.
Old 06-11-2016, 08:24 AM
130fe 130fe is offline
I had a similar issue with my old Rick's EFI tank (that I had bought a few years ago). It had check balls integrated into the tank plumbing to prevent those type of starvation issues. . It would only do it when it was hot and about a 1/4 tank or less). Put in a Vaporworx style one and have had zero issues since (regardless of fuel level or outside temperature).
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
