Old 03-27-2016, 11:21 AM
Project_Gotham Project_Gotham is offline
Default Hydroboost engaging without pedal
Took the car for a shakedown run and it seems to be fine until after 15 minuets of driving. Seems as if the breaks are slowly dragging progressively to the point where it comes to a complete stop, without pressing the pedal, from a 5 mph roll. Then I shut the car down, restart and it goes away until another 5 mins of driving. Any ideas???
Maybe a back pressure issue? DO I need to vent the res cap? I saw one post where they eliminated the "T" from the low pressure side on the HB and steering box and ran dedicated lines for both on the PS reservoir.. I am not using a PS cooler.
I did hear some type of burping noise when I shut it down but I am unsure if that is from the PS fluid or the PCV issues that I am currently trying to work out.
--Mark Stielow Wannabe--
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
2014 Chevrolet SS Sedan
Old 03-27-2016, 01:22 PM
Loosened the PS cap and seemed to help, I was able to drive longer but by pulling the brake pedal and holding it to disengage the brakes. Seems like a back pressure issue.
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
Old 03-27-2016, 08:25 PM
My guess is that you have the pushrod too long and it's applying a slight pressure on the master cylinder. Go under the dash and grab that pushrod and see if you have ANY play fore and aft. Also check your dead peddle adjustment. Should have some movement there before engagement.
If nothing else - make your pushrod shorter and see if it helps.
Old 03-27-2016, 10:46 PM
Thanks, I will look at it. I did notice there is not a return spring. Not sure if I need one since springs were for non power brake cars. I'm going to connect one to see if it helps.
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
Old 03-28-2016, 07:37 AM
I've never worked on a car that didn't have a return spring....
Old 03-28-2016, 11:00 AM
3_z28camaro's Avatar
3_z28camaro 3_z28camaro is offline
The pushrod is definitely a good thing to check.
Also try eliminating the "T" I have read many similar threads to this and running that dedicated return line seems to resolve the problem many times.
http://www.pro-touring.com/threads/8...es-w-Hydratech
1971 RS Camaro
Old 03-28-2016, 02:57 PM
funbnme's Avatar
funbnme funbnme is offline
I believe the piston in the master cylinder is held in place with a snap ring. Pull the master cylinder and make sure the snap ring that holds the piston isn't twisted.
If it's twisted (I had it happen to me once), a little bit of pressure would be applied to brakes and the pads would heat up from dragging and that expandes the fluid in the caliper. The fluid expansion winds up applying the brakes.
Also use a caliper to measure the length of the pushrod and make sure it's not a hair too long for the master cylinder.
Dan
1968 Camaro RS
408 - 4 speed - houndstooth interior
Old 04-04-2016, 11:00 PM
Well turns out the rod needed some adjusting and my PS pump is needing the control valve fitting to bring it down from 3.5 gpm to 2.2 gallons per minute. Good info to anyone running a Vintage air Front Runner with a hydratech system. Thanks.
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
