Old 03-28-2016, 09:30 PM
malo69 malo69 is offline
Default reverse lights
I have been trying to figure out the reason why my digi light reverse doesn't come on when in reverse? I have a 69 camaro with a ls2 with a 6 speed . I found the pink and green wires under the dash . where do I connect the green wire for the rear reverse lights ????please help thanks
Old 03-28-2016, 09:51 PM
randy randy is offline
not sure about colors but it goes into your transmission. When you put the car in reverse the transmission completed the path and sends power to your reverse lights. Think of your transmission as a house hold light switch
Old 03-28-2016, 10:00 PM
thanks but shouldn't it come from the ECM ? So I need to run a wire from the trans but where ? thank you again
Old 03-29-2016, 04:09 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Green wire goes to one sided the reverse switch on the tranny and then the other side to the BU lights.
ECM plays no part in it. Basically the green is 12v power. When in reverse the switch in the tranny closes and you get 12v at the BU lights. The BU lights are grounded in the trunk.
Old 03-29-2016, 07:36 AM
Thanks for the in info. I will work on it this weekend. I willl let you know if it works. You guys are awesome Thank you
Old 03-29-2016, 08:42 AM
130fe 130fe is offline
Thumbs up
The reverse switch is on the pass side of the T56. Make sure it is connected to your body harness. If you need the pigtail, they can be purchased off of eBay. What harness are you using? When I put an AAW classic update harness in my car, I ended up re-routing the pink and green reverse lights wires that were in the dash harness through a couple of unused slot on the engine harness plug (from the fuse block) and just extending those wires to the switch. I could have just ran them through the shifter hole but didn't.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-29-2016, 06:54 PM
Thank you guys. I did find the two wires under the dash .I also installed AAW awesome harness. I'm about to look up the pig tail on Ebay I will work on installing it this weekend. Will keep you posted
