Old 03-29-2016, 06:05 PM
rich's Avatar
rich rich is offline
Default LS3 reduced engine power
trying to determine why my ls3 conversion intermittently goes into reduced engine power mode. When the problem started I could turn off the engine and restart it and the problem would go away. I have replaced the electronic accelerator and the problem is back. Any ideas?
Old 03-29-2016, 06:50 PM
TheRealTC's Avatar
TheRealTC TheRealTC is offline
it may be running in the Regular Gas mode vs the Premium Gas Computer Map
Old 03-30-2016, 08:23 AM
130fe 130fe is offline
Is it giving you any codes?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-31-2016, 04:23 PM
rich's Avatar
no error codes
Old 04-01-2016, 03:24 AM
71RS/SS396's Avatar
This usually occurs when the ecu sees a difference between the commanded position ( throttle pedal position ) and the actual position of the throttle body, or a complete loss of signal from either one. I'm surprised you don't have a TAC fault of some sort. Is it possible the codes have been turned off?
My car did this intermittently, I found if the secondary safety latch on the throttle pedal plug was not locked in it would periodically loose the signal, ever since I pushed that in on the plug I haven't had a problem. I would suspect either the throttle pedal, throttle body, or wiring.
Old 06-01-2016, 06:58 PM
rich's Avatar
bought code reader. P2127 is the error code. I replaced the accelerator pedal and still have the problem. would you suggest replacing the TB or the TB electrical connector?
Old 06-01-2016, 08:17 PM
randy randy is offline
dont you need to calibrate the pedal? I know i have that option in the solous scanner. Had a chevy HHR that would do that until i replaced the pedal
Old 06-02-2016, 04:49 PM
rich's Avatar
what is the procedure to calibrate the accelerator?
Old 06-04-2016, 08:54 AM
TomM's Avatar
TomM TomM is offline
Try unplugging the mass air flow sensor and see if it quits doing it, if so, replace the MAF.....
T,
Old 06-22-2016, 06:06 PM
rich's Avatar
finally fixed the problem. it was a bad wire splice going to the accelerator. Glad to have that off the list.
