Old 04-04-2016, 04:08 AM
vstol vstol is offline
Default Check Engine Light (Mil) not working (LS3)
I put a LS3 into my 71 Corvette with a GM ECM. The check engine light does not come on when I turn the key. I have the mil wire from the ECM to the light and a ground coming from the light. I read somewhere while I was trouble shooting that the ECM has the ground so do I remove the ground from the light? Thanks
Kevin
Old 04-04-2016, 01:16 PM
Rechecked the directions and it says the ECM supplies the ground for the MIL light. It says this circuit requires a 12 v low current light ( have it) and an ignition power source. So does the ECM wire go where the ground is on the light and a 12v power source to the light as well? Thanks
Old 04-04-2016, 03:10 PM
cpd004's Avatar
cpd004 cpd004 is offline
This is how mine was wired. One side of light (ground) was supplied from ECM and the other to a switched 12v source that is 12v+ when cranking and running.
1971 Firebird
2017 SS
Old 04-04-2016, 05:21 PM
Bingo it works thanks
