Old 04-07-2016, 09:56 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Default LS7 dry sump tank
Other than the stock and Peterson LS7 tank I'm thinking of building my own tank to better fit my Camaro. I remember seeing a tank IIMuch built and maybe Ironworks? That fit the passenger bulkhead. Is there anything special about the insides of the tanks or measurements of the baffles or even angles of the return line? I want to keep it right around 11q or so and there is enough room for it.
Old 04-08-2016, 01:55 AM
Do some digging on www.aviaid.com they have some drawing,baffles,inserts, diagrams etc all pertaining to the ls7 oil systems . Could also go the route I probably will and just convert it to ls3 wet sump and not have to worry about cost, oil lines everywhere and possibly oil cavitation. Plus you'll gain a few hp with a wet sump
Old 04-08-2016, 07:19 AM
CamaroAJ's Avatar
That link has a ton of good information on it, thank you. I'm doing the dry sump as I plan on tracking the car and I tend to push pretty hard on things.
Old 04-08-2016, 07:23 AM
Ten fir ..(yes I did that on purpose) well good luck hope you get or find what you need
Old 04-08-2016, 08:16 AM
LS7 Z/28 LS7 Z/28 is offline
Just FYI, this is the opposite of what is true about dry sump vs. wet sump.
Old 04-08-2016, 08:35 AM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
Have you checked into any NASCAR or SCCA racing publications
Old 04-08-2016, 09:21 AM
OneCamaro OneCamaro is offline
Is this what you are thinking? This is on JA 2.0. Don't know how they did the inside.
Old 04-08-2016, 10:11 AM
CamaroAJ's Avatar
I haven't seen that one before. I was thinking IIMuch and Ironworks were squared off and fit in place following the stock body lines.
Old 04-08-2016, 11:14 AM
ironworks's Avatar
[QUOTE=CamaroAJ;634660]I haven't seen that one before. I was thinking IIMuch and Ironworks were squared off and fit in place following the stock body lines.[/QUOTE
I bet that unit has a separation baffle from the round area to the box on the side. I have never heard anything good about square dry sump tanks.
The one we put in the cowl of my Camaro was round.
Old 04-08-2016, 11:43 AM
actually on this motor with a stock set-up yes it is quite true ...one of the major magazines tested a ls7 and then swapped it over ...actually it could have even been horsepower tv ...regardless it was somewhere in the 7-11 hp range
correction 3-4 hp thru the rpm range heres the link http://www.hotrod.com/how-to/engine/...mp-conversion/
