Old 04-10-2016, 11:11 PM
COYBILT's Avatar
COYBILT COYBILT is offline
Default 2007.5 Gmc 3500hd Crew Cab Dually
Item Location (City/State):Livermore,ca
Price:20500 firm
Description: I am selling our shop dually as we no longer need the truck due to purchasing another truck. The truck currently has 220,000 miles on it. This truck is a fully loaded SLT model with a silver birch metallic exterior and a light tan and gray interior. The truck comes with a 7 pin connector in the rear bumper and inside the bed, back up sensors, Duramax 6.6 diesel, Allison 6 speed automatic, power windows, remote start, power driver seat, power rear slider, XM radio, On star, power locks, power steering, power brakes, Reese Goose neck hitch and ALCOA aluminum wheels.
Now for the performance add ons: EFI live 5 position tune, MBRP 4 inch exhaust, K & N cold air Intake, 2011/ new LML driver side exhaust manifold and a Diamond Eye down pipe. I still have the factory exhaust system for the truck that comes as part of the sale.
The truck recently received a full service from us from front to rear, Oil lube filter, fuel filter, trans filter, gear oil, and full grease of all grease points using nothing but redline synthetic.
New HANKOOK tires were recently added to the truck with only 1000 miles on the tires now
The brake pads, rotors and brake fluid were replaced at 205,000 miles.
Changed ALL U joints and carrier bearing in driveshaft at 205,000 miles as well.
We have check injector rates, etc and this thing needs to be seen and driven to be appreciated.
This truck is loaded and has been nothing but good to us.
The truck used to haul a flat bed car trailer and two car Gooseneck trailer occasionally. The truck pulls these trailers excellent and Has me sold on the GM Duramax platform, The truck routinely would knock down 19-21 MPG on the freeway and 14-16 around town. If you were to throw a 2500lb single car trailer plus a 4000lb car behind it, it would still knock down a impressive 16-18 Mpg on the freeway. The 40 foot enclosed trailer with two cars in it was around 14,000lbs and it would still get 12.5-13.5 mpg with. We loved and cared for this truck like some of the premiere muscle cars we build. It received redline 15-40W every 6,000 miles with a new wix filter, then at the same time a Wix transmission filter would be replaced as well as the fuel filter. I truly Loved and still love the truck, It needs to go to a good home where someone will do this same maintenance schedule with it. every 15k miles the gear oil would be changed in the rear differential with Redline 75-90w synthetic GL5. The coolant was changed at 125k and 200k.
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
