Old 04-16-2016, 11:13 AM
Default Dse booster master
Hi stupid question but the master comes with -20 and -18 threads in the master how do you step those down to 3/16 line?
Old 04-16-2016, 11:36 AM
dhutton dhutton is offline
SUR&R part numbers BR150 and BR155. If you do a lot of this buy the whole kit, part number BR-EZ316. It includes 25' of their copper nickel line and 112 pieces of various fittings.
Don
Old 04-16-2016, 12:58 PM
Don
Thanks Don those go to the master then do regular 3/16 double flare go to them?
Old 04-16-2016, 01:04 PM
These are flare fittings for 3/16 line. No additional fittings needed.
I know you can also get adaptors that accept the 3/8-24 flare fitting but this seems cleaner. Edelman makes those adaptors.
Don
Old 04-16-2016, 01:06 PM
Don
You are awesome thank you!
Old 04-16-2016, 02:51 PM
Default Routing examples
If anyone has any good line routing examples (I am not using a distro block) just an adjustable prop valve ... I woul love to see some good ideas
And Thank you to everyone on this forum the help advice and support are allays so great!
Old 04-18-2016, 10:23 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Here is what I did on my DSE booster/master with a wilwood proportioning valve. Don't know why the pics loaded sideways.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
