Old 04-17-2016, 07:51 PM
70 tt rustang's Avatar
70 tt rustang 70 tt rustang is offline
Default exhaust manifold gasket sealing
I have a gasket leak the shop that did the work used some kind of sealant on them now i have to clean it up and put new gaskets on the gaskets were felpros and the correct size wide bolt pattern for dart heads. Should i used some kind of sealant again and what kind and on both mating services? Iam a little lost here
thanks
Old 04-21-2016, 08:45 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
There should be no need for any sort of gasket sealer on header gaskets. I have been using Percy's dead soft aluminum gaskets and have had no leaking at all.
http://www.summitracing.com/search/b...ibanner=SREPD5
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 05-09-2016, 07:52 PM
