Old 04-21-2016, 11:45 AM
crisco crisco is offline
Default Issues with American Powertrain hyd clutch
I installed a hydraulic clutch in an '69 Dart. It already had the TKO 5 speed in it. The clutch will not release until the pedal is all the way on the floor. This makes it hard to shift even under normal cruising conditions.
I did their measurements and came up with needing one shim (.060) between the collar and the TO bearing retainer. Is this my issue? Does it need more shims? I am using the stock bellhousing also. The pedal has great feel and isn't too stiff.
Any help would be appreciated.
Chris
Old 04-21-2016, 12:08 PM
Che70velle's Avatar
I've read threads like this one, and it turned out that more bleeding was required to get the air out. If I were you, I'd re-bleed, before I tore it back down.
Every clutch setup is different, so guessing about your .060 shim isn't feasible.
What hydraulic kit did you purchase?
Thanks Dad!!
Old 04-21-2016, 12:35 PM
Thanks for the advice. I will do that.
This is the kit....
http://americanpowertrain.com/i-8521...3-4-speed.html
Old 04-21-2016, 02:53 PM
SSChef SSChef is offline
Chris
do you recall what the air gap was? sounds like it may be too much.
Old 04-22-2016, 07:01 AM
SilverOverdrives's Avatar
SilverOverdrives SilverOverdrives is offline
I agree with Scott, sounds like there is air in the system.
Jeff
Jeff Kauffman
VP Sales and Marketing
Silver Sport Transmissions
2250 Stock Creek Blvd.
Rockford, TN 37853
844.609.8187
Web: www.shiftsst.com
Email: [email protected]
Old 04-22-2016, 02:17 PM
Not right off, but I am going to double check that. Car will be in shop Tuesday. Thanks again for your help fellas
Old 04-23-2016, 03:20 PM
68Cuda 68Cuda is offline
The gap they told me to run was 0.15" to 0.20" with my kit, which is similar. I set mine at 0.15" but have not installed the master in the car yet to test.
http://www.forabodiesonly.com/mopar/...&postcount=370
http://www.forabodiesonly.com/mopar/...&postcount=371
Michael
Plano, TX
1968 Barracuda Notchback
Body & Paint:
http://www.forabodiesonly.com/mopar/...dy-2014.10252/
Engine:
http://www.forabodiesonly.com/mopar/...ictures.10230/
Old 04-26-2016, 04:49 PM
I bled the system again. Still didn't correct the problem. So, I moved the rod down on the pedal a inch and it fixed my problem.
Thanks for all your suggestions guys.
Chris
