Old 04-22-2016, 01:08 PM
Shiner's Avatar
Shiner Shiner is offline
Default Rear Brake Orientation Facing Front or Back?
My new rear Baer SS4 brake kit will give me the ability to orient the calipers facing forward or rearward. I am thinking of doing them on the opposite side and put them forward to give my coil overs and exhaust some breathing room.
I was curious if there are any pros and cons to the different orientations of a caliper.
1970 Chevelle SS
408 Forged LSX, LSA Blower, 4L80E, Ridetech HQ, Baer Brakes, Weld S71b
1997 Dodge Viper GTS
Heads, Cam, Bolt On's, BBS Wheels, Moton Suspension
Old 04-22-2016, 04:18 PM
Vince@Meanstreets's Avatar
If you look at most of the modern super cars the calipers are mounted forward.
With our cars and adaption, it comes down to available space.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 04-22-2016, 04:38 PM
Shiner's Avatar
Thanks Im gonna put them forward
1970 Chevelle SS
Old 05-12-2016, 09:12 PM
I don't see how it makes a difference. However is you're using the parking brake kit, the calipers only go one way.
Old 05-13-2016, 05:42 AM
SSLance's Avatar
SSLance SSLance is offline
I swapped my Explorer rear calipers around to the front of the axle to gain frame clearance. I had to switch calipers side to side to keep the bleeder screws up top and extend e-brake cables as they now enter from the rear.
I had an instructor at a HPDE event tell me by putting the calipers on the front it creates more braking grip as the brake is pulling the axle down whereas when on the back it pulls the axle up when brake applied.
I go both ways on that, thinking it makes sense and not sure if it does or not. If so, it's just an added benefit from something I did out of necessity for room.
Lance
Old 05-17-2016, 11:47 AM
GrabberGT's Avatar
GrabberGT GrabberGT is offline
I watched this video a couple months ago and thought it was pretty interesting. It comes down to packaging for most of us but per the discovery in the video, its about keeping the weight as low and as centered as possible.
https://www.youtube.com/watch?v=HEIk0hJ7eGk
Chris
Its not a Vega!!!!
Total Cost Involved - Total Control Products - Gateway Performance - Fatman - MaverickMan Carbon
