Old 04-22-2016, 01:09 PM
Swain's Avatar
Swain Swain is offline
Default LS3 0821 cylinder heads
Does anyone know the new part number for these heads? #0821
One of mine is cracked and I don't want to spend the money on two heads right now.
Thank You
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 04-22-2016, 07:17 PM
Che70velle's Avatar
Jason, there are several variations of that particular head casting. If you research "LS3" cylinder head, you'll see what I'm talking about. I doubt you'll find another 821 casting, not needing work, but I could be wrong. Hopefully you can. It's difficult to find CORRECT info regarding your particular casting numbers chamber size, port volume, etc. There is a lot of conflicting info out there.
If I were you, I'd buy replacements as a pair to ensure equal chamber size, port volume size, etc. I understand the money side of this, but I know you hate doing things twice as much as the rest of us do. Here's a decent price on the equivalent head that you have. You can actually buy the LSA heads a little cheaper from Summit, but you'd need to compare volumes to ensure your getting what you actually want, and not losing power due to compression ratios, etc.
http://m.summitracing.com/parts/nal-12629063
Thanks Dad!!
Old 04-23-2016, 07:57 AM
Can you get a 823 casting as just swap the valves?
Old 04-23-2016, 07:19 PM
Swain's Avatar
I welded it up and it's fixed for now it seems.
Let's hope that works until I change the heads later on
Jason Swain
