Old 07-17-2006, 07:11 PM
fletcherscustoms fletcherscustoms is offline
Default Lots of stock 69 SS parts, glass, brakes, some aftermarket goodies also
First things first this is like a swap meet , I am open to bargains and trades! If its not on the list I don't have it available or its not for sale! All the parts are in great shape , unless noted. All they need is a little cleaning and they'll be good as new. Some are new aftermarket, some are NOS, and some are used original parts off of a 69 SS 350 car. If it marked as "NEW" it most likely still in package also. I have pics of most anything listed or can get pics ASAP. Everything is laying out on my shop floor and must go ASAP!!
If you have emailed me before and wanted something and were awaiting on me to get the full list, you have first dibs
Here's the list
-- $500 350/300 HP out of 69ss. motor is tore down for rebuild and needs cleaning and rebuild. 4 bolt main block, crank, complete heads, 4 barrel stock intake, oil pan, pistons, push rods, balancer,PS pump and line set, oil pump, misc bolts, head bolts, alt bracket, dip stick!
*Motor #'s 3970010 J35 Above filter 136n 386 371
* Head #'s triangle with 882 11 GM11 333882 G0165
* intake #'s 3827184 GM5 CONV4 226 8
--$200 3 speed manual out of 69SS car
*#'s C27 8911982 18n651308
--$100 DSE rear Koni shocks for mini tubbbed car
--$75 69 ss rear quarter glass green
--$45 69 x-11 clear glass, one is a Safety Plate aftermarket
--$100 69ss Green door glass
--$300 Complete 69 SS front disc brake setup, Spindles are powder battleship grey, steer arm powdercoated black, caliper brackets powder coated black, dust plates powder coated grey, stock cailpers need welding and turning, front frame line brackets all powder coated black
--$100 Stock 69ss Proportioning valve very good condition
--$150 Stock 69SS power brake booster , master cylinder, valve, and pressure sensor. Coat of paint and it would be good as new, very very good shape
--$200 69SS Stock upper control arms, perfect condition, powder coated black, Moog Ball joints, with stainless bolts, and new poly bushings. new stops
--$100 69SS Lower Control arms , powder coated black, previous owner powdercaoted and did not smooth any pitting first, still would show good on a driver car
--$100 69 X11 Stock upper control arms, some surface rust on top primer, needs ball joints and ushings
--$100 Aftermarket New upper bucket seat foams, no wire
--$50 69SS trunk latch with full support piece, and two hole lock holder, very good condition
--$75 Stock 69SS Clutch, brake, and gas pedal, good shape need paint, bushings, and covers
--$15 Stock 69SS gas tank straps, need blasting and paint
--$5 Stock 69ss 12 bolt rear rubber stop bumper
--$100 Stock 69ss Wiper motor with arm assembly, arms need blasting and new chrome
-- $100 (2)69ss stock hood hinges, need blasting and paint
--$100 69ss A/C condensor with box, and outer blower motos assembly with box, inner box has two rust throughs on bottom side
--$25 69SS (2) stock headlight mounts and buckets, need blasting and paint
--$15 69ss rear center bumper mount, needs cleaning and paint
--$20 69ss upper seatbelt holder clips, good chrome
--$25 69ss (2)inner fender braces, fender to firewall, need clean and paint
--$10 69ss vent cables
--$40 69ss tailight buckets and one lense, need paint
--$40 (4) 69ss door hinges, need pins and paint
--$20 Aftermarket OEM brand door window felts
--$50 American Auto Wire Console guage wire harness, new
--$75 69ss Guage cluster, with Speedo, fuel, headlight switch, and wiper switch. Top to mounting holes on driver side are cracked and broke at top, still useable
--$20 Autometer Sport Comp 2 1/16 Manual oil pressure guage, new
--$10 69 GM horn relay, not NOS, but newer unit from Ricks the is similiar to original
--$10 NEW Classic industries 69 Front console bracket
--$50 69ss Kickpanels with A/C, clean and paint
Old 07-17-2006, 09:59 PM
NvrDun71 NvrDun71 is offline
PM Sent
71' Nova - LY6, T56
Old 07-18-2006, 08:39 AM
Lance-w Lance-w is offline
I'm interested in the engine. Where do you live?
Thanks, Lance
Old 07-18-2006, 09:23 AM
Georgia
Old 07-18-2006, 12:15 PM
Guess I'll pass then. Just a bit far to pick it up over the weekend
Thanks anyways, Lance
