Old 04-26-2016, 12:39 AM
black67malibu black67malibu is offline
Default 71 turbo Ls Nova
Item Location (City/State):
Eureka, Ca
Price:
$35,000
Description:
71 nova Turbo LS
71 nova clean title
Full ground up resto started about 3 years ago
Paints is a stock ford color that is a dark green. Almost looks black in most lighting. Ford gem green.
Motor:
Motor is out of a 2002 corvette (ls6) intake manifold
Corvette front accessories
Motor itself is a ls1
Transmission:
Costum built 4L80e from North Texas Converter
It's a stage 2 capable of 1000 fwhp
2500 stall with tci flex plate
Shift works shifter
Rear end:
Ford 9" with big bearings
Tru track
Moser 31 splin axles
3:50 gears
Breaks:
Wilwood disc in all four corners
Wilwood master, vacuum assist
Wilwood adjustable prop valve
Suspension:
Full ridetech suspension
Single adjustable coilovers
Front sway bar from ridetech
Ridetech tru turn
Ls swap kit from BPR
Turbo kit:
Stock ls manifolds with custom hot side
Turbonetics t4 .76 compressor and .75 exhaust
Precision wastegate
Turbo smart race port BOV
Treadstone intercooler
Custom intercooler piping
-10 oil return
-3 oil feed
Custom 4" Mandrel bent exhaust. Stainless with magniflow muffler
Dumps down before axle. Beautiful tig job with custom connection fitting
Mightymouse solutions pvc catch can( best in the industry )
Fuel:
Tanks inc tank
Fuel pump GPA-6 1000hp pump
Nasty performance fuel line and fittings
Corvette filter
Summit fuel guage
60lb injectors
Interior:
Custom 2 tone leather
Lokar fuel pedal
Lokar brake pedal
Lokar handles and window handles
Gauges:
Dakota digital dash with all electronic sending units for fuel and water
Innovate PSB-1
Boost and wideband all in one gauge
Gauge will control boost per gear
Shift light
If it sees a lean condition it will cut boost
If it over boost it will cut boost
Also will datalog
Electrical:
Optima red top
Moroso battery box
Flaming river cut off switch
0 gauge to hot spot on firewall
2 gauge running from alternator to charge battery
8 gauge to fuel pump
Everything has kicker fueses on each end of hot side in case of wreck they will pop and not catch the car on fire
All headlights and fans run on own relay with built individual fues panel
All accessories run off of relays too
Steel 16" Rally with new tires
The car runs and drives great! Just finished all the small stuff and its time to sell. Asking $35,000 OBO. For more info please call 707-three62-six556. Thanks for looking.
See craigslist add below for photos. Thanks, Tyler.
http://humboldt.craigslist.org/cto/5534941816.html
Old 04-28-2016, 10:00 PM
boonedog boonedog is offline
Love it! Good luck with the sale
Old 05-08-2016, 06:52 PM
Price drop to 30k. Need gone to buy a house, thanks.
Old 05-23-2016, 09:20 PM
gnx7's Avatar
gnx7 gnx7 is offline
I was curious if you ever had a chance to run it at the strip and how it did?
What boost setting and fuel?
Old 06-21-2016, 09:19 AM
EpikRider EpikRider is offline
Is this car still for sale by chance? CL ad expired....thanks.
