Old 07-18-2006, 12:41 PM
MaxHarvard's Avatar
Default thank god for regular maintenance!!
I thought to myself today... i should change the plugs in the camaro. its been 2 years, might as well!
Sure enough, i found a broken spark plug, and one plug with nearly ZERO gapping.
Yea, she ran a lot better after that! YIKES!
Old 07-18-2006, 12:50 PM
Matt@Lateral Dynamics Matt@Lateral Dynamics is offline
I'd be pulling the heads off as soon as possible if I were you. Broken plugs don't just happen.
Old 07-18-2006, 01:06 PM
MaxHarvard's Avatar
The spark plug was broken at the wire end (i probably bumped it putting the headers back on), not inside the motor... other wise i'd be having a heart attack! LOL
Old 07-18-2006, 04:47 PM
Clockwork's Avatar
Clockwork Clockwork is offline
Good catch, but what about the one with almost zero gapping?
Dean
Old 07-18-2006, 06:17 PM
BC69's Avatar
BC69 BC69 is offline
I am by no means highly mechanically inclined. But wouldn't a broken plug have some significant or obvious effects on the motor and how its running???
Good catch though! I dont even know how to change plugs, so I am not insulting at all, just asking.
In memory of those gone before us
In gratitude for those who care.
Old 07-19-2006, 06:39 AM
MaxHarvard's Avatar
that was most likely installed when i had the engine built, i had not touched the plugs since then.
BC69: A broken plug basically means that the one cylinder wasnt firing, it was coated in oil. I was running on 7 cylinders! YIKES!
